Bit of backfire
Old May 12, 2017 | 10:57 AM
Hellz's Avatar
Hellz
Default Bit of backfire
Hey all,
Just wanted to ask... so now the car has 750 odd miles on it and I know I'm probably going to get scolded for this but I couldn't resist a couple of hard acceleration merges onto the highway.. and beyond the obvious adrenalin rush I got a couple of backfires back to back at higher rpm before you ask yes it's an 8 speed auto and I was not fooling with the paddles whatsoever, my last 2 cars were manual and I live in NYC so I just couldn't get another stick.
But are the backfires normal or should I be worried just looking for opinions and nothing goes in my tank except 93.
Also would be prudent to mention that when I took delivery the car had 8 miles on it.
Out of 8 pulls I got back fires twice, just me being paranoid ?
Old May 13, 2017 | 07:33 PM
EmbraceNext's Avatar
EmbraceNext
I have the same issues on my 17 GS CE. It is an auto with 800ish miles. This happens on shift at high RPMs.
Old May 13, 2017 | 08:12 PM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
Not an issue on high rpm hard acceleration shifts, especially on the 1-2 shift. Some cars like Mini coopers alter their tuning in sport modes to try and recreate the effect. It's normal.
Old May 13, 2017 | 09:43 PM
EmbraceNext
Ok, thank you! Just watched this vid. Go to 6:15 and you can hear them there as well.
Old May 13, 2017 | 10:18 PM
NSC5's Avatar
NSC5
Normal by design, engine power is briefly interrupted which allows a much faster shift.
Old May 13, 2017 | 11:29 PM
Higgs Boson's Avatar
Higgs Boson
a backfire is combustion taking place in the intake manifold, hence "back"fire. if you are hearing popping sounds in the exhaust that is a result of late combustion from retarded spark possibly mixed with a retarded exhaust valve close event, both normal through heavy/wot throttle shifts.
the auto tune will pull timing (which means fire the spark plug later in the stroke) to cut power briefly for the shift and you are hearing the little brap noise, which is cool so enjoy it. Floor it all the time.
Old May 14, 2017 | 02:15 PM
Hellz's Avatar
Hellz
Thanks guys I feel better now 😁
Old May 15, 2017 | 05:45 PM
ya3coub's Avatar
ya3coub
I don't have it on my car it's Z51 Manual
sometimes i hear the poping on high revs while on neutral only, I wish if I can get some back fire without the tunning as it's not good to the engine
To Bit of backfire
