C7 main cat delete kit
Old May 14, 2017 | 10:23 AM
NORCAL-SS's Avatar
0NORCAL-SS
Former Vendor
Default C7 main cat delete kit
[size="3"][size="4"]FITS BOTH STICK SHIFT AND AUTOMATIC CARS C7 OR C7 Z06
The OEM manifolds flow well but the main kinks in the system are the main cat pipes and also the mid pipe.
In stock ready to ship
$739 shipped to the lower 48 states
3" stainless steel
Bolt in deal
Replaces oem pipes from manifold exit to midpipe entry
Pipes are farther away from oil cooler/lines to keep temps lower
Ceramic coating is optional
I can set you up with a paypal bill or you can shoot me a paypal payment tony@c7z06owners.com
I can also offer a corsa mid pipe to make it a bolt in deal which is $549 shipped.
INSTALL (I highly recommend getting the corsa x pipe at same time which I can set up)
1.Disconnect battery
2.Remove tunnel brace
3.remove X-pipe
4. Unbolt engine mounts from cradle 5. Support engine
6. Lift engine
7. Unbolt cradle (6bolts)
8. Remove bolts from flange
9. Install off-road pipes
Old May 14, 2017 | 10:26 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I'm guessing that the ECM needs to be programmed to stop the codes from popping up?
Elmer
Old May 14, 2017 | 10:30 AM
NORCAL-SS's Avatar
0NORCAL-SS
Former Vendor
no use a 02 simulator. Big daddys 90s has worked on a c7 z06s or you can tune if you want to.
Old May 14, 2017 | 11:00 AM
NoOne's Avatar
NoOne
Why go through all that instead of a cheap set of Mid lengths at nearly the same price since you need to buy the X pipe anyways.
Old May 14, 2017 | 11:25 AM
NORCAL-SS's Avatar
0NORCAL-SS
Former Vendor
easier install
cooler oil temps (oil cooler set up)
lower engine bay temps
NORCAL-SS's Avatar
0NORCAL-SS
Former Vendor
easier install
To C7 main cat delete kit
