Want the cleanest looking Flex Fuel kit on the market for your C7? We have the solution. $349 for our custom kit (requires tune before you run e85). Easiest 30whp (approximate) you'll get for your NA C7. We can ship anywhere
Is this a preferred option for a Supercharged C7 Grand Sport on meth?
You'll need a low side fuel system in order to run flex fuel. Not enough volume with the stock system. This is what we have been working on with Fore Innovations and have successfully completed two cars as of now.
Originally Posted by TRANS DAMM
z06 kit?
This will work on a Z06, yes. You will also need a low side system to keep up with volume demands.
Well I will keep an eye on this thread for sale updates! Any suggestion for low side fuel?
You don't have to run a low side fuel system. You can get away with about e45 with your setup. I run e47 with a stock low side and make a bit over 900 to the tire. The low side for sure helps, but it's not a definitive must.
Great looking flex fuel kit. Love how clean the install is.
I run full blown E85 on my setup but I have the 32% fuel lobe on the cam. I'm only at 750rwhp. Still on the stock low side as well as LT1 injectors and HPFP.
no way you're doing that without meth injection. Either that or your dyno reads higher than any dyno known to man.
hey guys do you sell that fuel line without the sensor?
i ask because i got the dsx kit with that solid line and it wiggles and rattles so much its putting preassure on the orings and it gave out causing a huge fuel leak in the engine bay,
i guess using the car on track days taking turns constantly it was not designed for it.
if anyone knows where I can buy that flexible fuel line i can remove the solid one and tuck it in nicely like in this picture.
