Negative Camber
Old Jun 17, 2017 | 12:30 PM
RADAR B8's Avatar
RADAR B8
Default Negative Camber
Do the wheels on 2017 Grand Sports all have negative camber from the factory that is noticeable with our eye?
Old Jun 17, 2017 | 08:22 PM
BEZ06's Avatar
BEZ06
I don't know what the factory alignment specs are for a GS, but I assume they're probably close to the Z06. Or maybe somewhere in between the Stingray and the Z06.
Below is a sheet with the 2015 factory specs, and you can see the camber ranges from -0.2° to -1.1°.
So....if you can see something that's probably less than 1° on the GS, then I guess it's "noticeable with our eye". I can't really tell that myself by looking at the wheel - especially if it's down like a Stingray at 1/2° or less.
Old Jun 18, 2017 | 12:41 AM
tiger013's Avatar
tiger013
My negative camber on my GS was pretty bad. My inner rear tires would of worn quickly. I just had the dealership do an alignment to straighten them up. I won't track the car so I perfer better tire life.
Old Jun 18, 2017 | 06:24 PM
Hutch66's Avatar
Hutch66
I was just browsing through my owners manual. Gotta love American cars.
In it says how to adjust your camber for the track and gives you the spec. and tire pressures. And for which model.
I always run 4-5 psi under for the track and the manual agrees.
Old Jun 23, 2017 | 04:27 PM
DAAANG's Avatar
DAAANG
Just had my GS aligned at 2000 miles, and yes, 3 of 4 wheels were out of spec on camber and rear toe was off. Get the car aligned, Bowling Green not great at getting it right prior to shipping. And prior to alignment, it did look like my car was off to the naked eye.
Old Sep 15, 2017 | 05:03 PM
Jjach's Avatar
Jjach
https://www.corvetteforum.com/forums/c7-z06-discussion/4042562-dialing-in-negative-camber-using-a-laser-temp-gauge.html
Old Sep 20, 2017 | 11:42 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
We've owned four new Corvettes, every one of them had at least one parameter that was outside of even the hugely wide GM specs.
Some time between 1k and 3k miles, dream up some silly complaint about handling and have the dealer check the alignment under warranty.
Old Sep 21, 2017 | 09:40 AM
village idiot's Avatar
village idiot
New cars just settle and stuff in my experience. I've always been out of spec after a few thousand miles.
Old Sep 21, 2017 | 04:13 PM
TCorzett's Avatar
TCorzett
Factory alignment on my 2018 Grand Sport (non-Z07) after 2074 miles:
LF: -1.1° camber, 7.9° caster, 0.10in toe
RF: -1.1° camber, 8.3° caster, -0.04in toe
LR: -1.1° camber, -0.05in toe
RR: -1.6° camber, 0.00in toe
To Negative Camber
