OIL Catch CAN
I had the problem of getting oil in my air filter. Fix that by adding oil catch can. But still the problem remain. I'm not sure but the tuner guy said that the car have too much pressure? What does he mean , I don't now.
Any help will be appreciated.
Yes my car is
2014 c7 z51, with pro charger, stage 2 air intake, and upgraded pulleys.
Yes my car is
what are who's catch can do you have in your car. Plus check your oil you have to run the car at least 1/4 qt low in the dry sump cars are you need to do this. TELL US THESE QUESTION HERE. Robert
clean side contamination almost always comes from high crankcase pressure, and once in a while from overfilling or a clogged / undersized air filter.
crank pressure comes from increasing power beyond the stock pcv systems intent, switching to larger displacement, or larger clearanced racing pistons/rings, or worn/damaged engine parts.. sometimes more than one!
hopefully it is intuitive that a system designed to manage 450hp may cause side effect at 700 etc.
any system implementing a clean side catch can or a clean side separator, by installing this device, meant to trap oil (caused by crankcase pressure) is INCREASING crankcase pressure, due to inherent restrictions in the device impeding airflow trying to exit
when you have this symptom the best method is to equalize it at the source, and of course make sure the engine is as mechanically sound as possible, or turn down the power, but no fun in that last one :P
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
I did take couple of pictures hope they are good.
https://photouploads.com/images/a7ca3f.jpg
https://photouploads.com/images/7bc6e0.jpg
https://photouploads.com/images/11c048.jpg
https://photouploads.com/images/e4370e.jpg
https://photouploads.com/images/cbe1ff.jpg
https://photouploads.com/images/fd3a02.jpg
Thanks guys for your support.
Plus for me I have had 3 cans on my car wouldn't put nothing other than MMS can on any car like this at all. Plus I paid 700.00 for the 1st can that didn't work correct when under boost.
David at MMS will & did help me to really understand & sent me pic's by cell for me to get it correct.
Robert
while the size of the filter on the can may be too small to adequately handle supercharged crankcase flows, it would be one way to stop crankcase vent oil from entering the s/c system.
you probably need to remove the intercooler, other oily parts and wash them out.
