Memory seat problem
Old Jul 16, 2017 | 03:02 PM
Marine1965's Avatar
Marine1965
Default Memory seat problem
In my 2014 Z51 for the last few days I noticed my memory is not staying in my drivers seat....any ideas?
Old Jul 16, 2017 | 04:04 PM
jhauswirth's Avatar
jhauswirth
I had a seat memory problem. The cause I found was I had the exit position set to all the way back and all the way up that I could make it. If I moved the seat slightly forward it would move into the saved seat position for the button I would push. I then reset the exit position to be slightly forward from where it was originally set and I haven't had a problem since.
Old Jul 17, 2017 | 04:41 AM
Kraz8s's Avatar
Kraz8s
This is correct. Could also be a loose ground, lpos battery terminal connection, or your battery is going.
I had the same issue for months and took it to the dealer. After having my car for 3 hours and determining that nothing was wrong I no longer have the issue. I had went over everything thrice over so who knows.
To Memory seat problem
