C7 Z06 intercooler pump wire diagram
Old 12-04-2017, 08:24 PM
onebad1lE
onebad1lE's Avatar
Default C7 Z06 intercooler pump wire diagram
Does any body know how to wire then pump just power and ground and run the whole -when activated installing it in a grand sport with no plug for it
It has a 5 pin connector Thanks
Old 12-08-2017, 10:52 PM
Jetblackc6
Jetblackc6's Avatar
its a 5 pin connector but only 3 pins are used anyway. i would suggest a relay to power pins 1 and 5they are linked together, pin 4 is ground
Old 02-27-2019, 07:47 AM
Z06Norway
Z06Norway's Avatar
Can you confirm that 1 and 5 is same wire ?
So i can splice 1 and 5 together into new pump + pole ?
and use # 4 the black one as ground ?
will replace stock pump with a better one from bosch.
tia
To C7 Z06 intercooler pump wire diagram
Quick Reply: C7 Z06 intercooler pump wire diagram
