LT1 Low oil Pressure
4th Gear
MY 1994 LT1 has low oil pressure, no knocking. I replaced the sending unit and it got worse. Help. The hotter it is the lowest it running at 5-6 PSI hot
Good luck and I hope the repair isn't extensive or expensive.
I just chased one on conventional small block and it was the new EFI distributor partially unblocked an oil galley at the rear. They converted to EFI and lost oil pressure, so that was a weird one... but you haven't given us any other details.
Unless you know what happened, I'd drop the pan and throw another oil pump on it. If that doesn't solve it, check the mains. If that doesn't reveal it, the engine will have to come out I think.
Good luck! Don't get that Optispark wet!
