True stock bottom end WHP limit?
Old Aug 11, 2017 | 12:26 AM
FlatPlaneCrankDreams's Avatar
Default True stock bottom end WHP limit?
It seems like the accepted answer for engine failure around 700whp is the piston rings touching.
There are also plenty of guys making crazy power on stock bottom end 5.3s with the piston ring gaps opened up.
If the LT1 had the piston ring gaps opened up, what would be the max whp limit?
Ive read that the rods start bending around 800whp, but I feel that 800whp from a centrifugal blower is different than 800 whp from a positive displacement blower.
Old Aug 11, 2017 | 12:19 PM
Cordes Performance Racing's Avatar
Supporting Vendor
we have never had a lt motor break a piston and have quite a few making 800-850 rwhp. the only stock bottom end failure we have ever had was on a 990 rwhp c7 that doing 3 back to back half mile pulls eventually bent a rod. the pistons are not as weak as people will try and make you believe. i've seen plenty of files from people who had theirs brake a piston at 700'ish rwhp and the knock sensors were damn near off and timing was much higher than I would ever expect it to take.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Aug 11, 2017 | 07:58 PM
An answer from the man himself.
I know who to go to when I want to take the next power plunge.
Thanks!
Old Aug 15, 2017 | 08:41 PM
Supporting Vendor
[QUOTE=mesparza;1595342912]An answer from the man himself.
Thanks![/QUOTE
nice!!
To True stock bottom end WHP limit?
