Wavetrac differential
Old Aug 23, 2017 | 01:22 PM
olblue75's Avatar
olblue75
I see it for a 2008-09 Pontiac G8 and 2014+ SS nothing for a Camaro unless one of the SS or G8 have the same diff
Old Aug 25, 2017 | 10:15 AM
sales @ WXM's Avatar
sales @ WXM
Originally Posted by black_c7
Eddie do u know how much power would that differential handle for dig ?
Sorry for the delay!
If I had guess it should at least be 1200whp. It's so new we have yet to find out its limitations.
Old Aug 26, 2017 | 02:11 PM
black_c7's Avatar
black_c7
Originally Posted by robert miller
Your stock gears are your axle will brake before this piece will. If you are doing dig's & drag this is what you need. Robert
Isnt the problem with the spider gears! And does that solve it? I broke my spider gear making 425whp that how I know they are very weak
Old Aug 26, 2017 | 02:45 PM
JHEBERT's Avatar
JHEBERT
It eliminates the spiders, the c7 spiders are weaker than previous years partly because they increased the diameter of the cross pin. They break in half easy because of it. Smaller cross pin with bushings and hardened spiders will help a LOT. With 4-pinion spiders, this thread would never exist...
Old Aug 28, 2017 | 04:42 PM
robert miller's Avatar
robert miller
This replaces the S/gears I just got RPM to build me a new rear end with wavetrac & 3:42 polished gears & 500 mil axles for this new set up. Will be getting it in BG KY in 2 weeks at LS fest. Robert
Old Aug 30, 2017 | 11:39 AM
rflow306's Avatar
rflow306
The four pinion set-up should have been standard. Thanks to instructions from Div7racer I was able to fix/upgrade mine. I have not had a chance to test it at the track yet.
C7 Z06 4-pinion set-up<br/>
The good thing is I can now send my old case and gears to rpm and build one with a wavetrac.
Old Aug 30, 2017 | 06:32 PM
JHEBERT's Avatar
JHEBERT
You won't need it, what you have will work just fine and is exactly what I am going to do. I spoke with div7 last year about this. Did you use the smaller diameter cross pin and use bushings? Also consider using hardened gears for all 4 spiders...
John
Last edited by JHEBERT; Aug 30, 2017 at 06:33 PM. Reason: I need that damn block and the 2 half pins with the radius!!!
Old Aug 30, 2017 | 10:41 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Old Aug 31, 2017 | 12:16 AM
black_c7's Avatar
black_c7
How much did it cost u to do that ? Its looks like it can take some serious power with those 4 spider gears,is there any difference in the car at high speed like 180 mph? and did u do it your self ? If yes can you please provide some instructions of how u did it and where did u get the patts, etc
Old Aug 31, 2017 | 09:08 AM
rflow306's Avatar
rflow306
Yes i did it myself with the help of a good friend, the parts and machine work was not very expensive. Thanks to the detailed instructions from fellow member div7racer, he deserves all the credit.
The expensive part was having to buy a new diff since both of my side gears sustained heavy damage. I would definitively suggest you do this before your unit breaks .
Old Sep 1, 2017 | 01:57 AM
black_c7's Avatar
black_c7
I sent u a pm would appreciate it if you check it thanks
Old Sep 11, 2017 | 02:46 PM
RichSobko's Avatar
RichSobko
Could you also set me up with some instructions. My Diff is whining pretty bad and with the cam I just out in I'm sure I'm going to break it.. I would like to fix it now before it's completely broke
Old Sep 11, 2017 | 05:15 PM
  #33
JHEBERT's Avatar
JHEBERT
Rich, what you prob hear is the ring and pinion, the spider gear upgrade is not going to remedy that. Upgrade your replacement diff, c7's have been known to leave bowling green with under-filled differentials.
John
Old Sep 11, 2017 | 05:19 PM
  #34
RichSobko's Avatar
RichSobko
Ya I checked my fluid and it seems to be full, I just don't wanna replace it with a new unit and it happen to be again. I should be around 900whp next year so just looking to kill 2 birds with one stone. I can't seem to find any ring and pinion gears available anywhere.
Old Oct 3, 2017 | 02:19 PM
  #35
David@MMS's Avatar
David@MMS
Supporting Vendor
interested in an upgrade to my 7z kit. these TTS making some TQ!
looking for help
Old Oct 3, 2017 | 02:24 PM
  #36
todd@rpmtransmissions's Avatar
0todd@rpmtransmissions
Former Vendor
looking for help
Give the guys at the shop a call, Jeremy or Shane will hook you up. We still have some of the wavetracs left.
Old Oct 6, 2017 | 04:28 PM
  #37
MIGHTYM0USE's Avatar
MIGHTYM0USE
just called in and got some $ numbers always a surprise there but hey comes with the territory.
see if you can massage quote before i call back on monday i'd appreciate you putting in the good word! you see what it's going under.
its already got the mph for 8.x just need to let it eat on the 60ft.
To Wavetrac differential
Old Oct 9, 2017 | 04:38 PM
  #38
MIGHTYM0USE
getting this going via RPM yay!
Old Oct 25, 2017 | 12:25 PM
  #39
MIGHTYM0USE
my z51 diff shows delivered to you today, sorry for the delay!
Old Dec 1, 2017 | 10:40 AM
  #40
MIGHTYM0USE
forgot to update. diff and axles upgrade got under the car just in time for the last test of the season
