Engine HP..need smart Gearhead!!!
Old Aug 25, 2017 | 04:14 PM
Dave502's Avatar
Dave502
Default Engine HP..need smart Gearhead!!!
OK......example LT1...460 HP?.....is that 460 hp in the enclosed engine room Dyno with no add on to put drag on motor like AC,Alt,Power steering transmission etc....or is that 460 hp to the rear wheels (rwhp)..if it is rwhp then you need to add approx 15% ( for standard Trans) to the rwhp to get hp to crank.....which would make the LT1 (460 rwhp + 15%=529 hp to crank (motor).....Talk to me...what is on motor when dynoed at 460?
Old Aug 25, 2017 | 05:10 PM
vetteZpilot's Avatar
vetteZpilot
12%-15% less than the 460 you have at the crank is what you will have at the wheels .
Old Aug 25, 2017 | 08:27 PM
Dave502's Avatar
Dave502
I agree 100%...that comes out to about 400 rwhp on stock LT1......Its amazing how many people have gotten base line dynos and their numbers are nowhere close to that.....Which means after their mods the hp is not close either....I know Mustang dynos are better for tuning and read about 10% less than a Dynojet which should be close....If you take the time to search a bunch of dynos it becomes funny..
Old Aug 25, 2017 | 10:19 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Dyno Dynamics read pretty much in the middle of dynojet and mustang. They are the closest to accurate I've seen.
Old Aug 26, 2017 | 05:10 PM
GarryZR1's Avatar
GarryZR1
Dave 502
The SAE rating is 460 hp at the flywheel. It includes all accessory loads. IN 1972 Socoety of Automotibve Engineers (SAE) changed the standard hp rating to include all engine loads. The rear wheel power will be reduced by an amount for the traansmission and differential and other drive train losses (inefficiencies).
I agree the RWHP will be 12 to 15% less than the 460 at the flywheel.
Old Aug 26, 2017 | 07:49 PM
Dave502's Avatar
Dave502
Originally Posted by GarryZR1
Dave 502
Thanks for the info....Does that mean that the top Dog in 1970 the 450 hp 454 Chevelle was really only 392 hp with 13% loss?...Just kidding ...The point is that all these shops that have dynos hacked up to show you that you have a lot more Hp and torque than you do should Quit that
Old Aug 26, 2017 | 07:59 PM
Dave502's Avatar
Dave502
I answered my own question from a article from Hagerty...
“Rear wheel horsepower was at least 30 percent lower than the reported gross figure, in some cases even more,” Campisano said.
Some Super Chevy readers must have been stunned to see that an LS6 Chevelle SS, with 450-hp rating, put down 288 rear wheel hp in the dyno test. That would have put a net hp rating at around 350 hp for that legendary big block.
Great article about 1972 hp change
https://www.hagerty.com/articles-vid.../13/horsepower
Old Aug 26, 2017 | 08:02 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Back in those days, auto makers used SAE Gross, which was with no accessory loads, no intake restrictions, no mufflers..... Hugely misleading.
Old Aug 26, 2017 | 08:07 PM
Higgs Boson's Avatar
Higgs Boson
actually I would consider it more accurate when defining actual engine horsepower. they don't call it "Engine HP with AC, power steering, emissions equipment, auto slushbox" they call it "Engine HP."
what this means is that engine advancements, drivetrain efficiency, and automotive technology in general has come even farther than we give it credit for.
Old Aug 27, 2017 | 12:02 AM
Bill Dearborn's Avatar
Bill Dearborn
The relationship between Gross and Net HP has changed over the years due to more efficient accessories. I used to have a 71 LS6 Corvette with a 425 HP 454 BB. That was gross HP. While I had the 71 I purchased the Assembly Manual that indicated GM was going to offer the same engine in 72 with a net HP of 330 HP but ended up never actually releasing the engine for build. Gross HP ratings were taken with no accessories and with headers Vs the stock exhaust manifolds.
With newer engines accessories have gotten more efficient and stock exhaust manifolds have also gotten more efficient so Net HP ratings are much closer to Gross HP if they actually measured gross HP anymore.
Bill
Old Aug 27, 2017 | 07:24 PM
falconhulk's Avatar
falconhulk
The truth is that before SAE became the agreed upon method, relatively recently, mfg's reported whatever they wanted using whatever method they wanted.
Old Aug 29, 2017 | 06:06 PM
thrilled's Avatar
thrilled
460 hp at the crank.At the wheel approximately 405-420.
Old Aug 29, 2017 | 06:26 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
You lose more than 10%. 14-15% is more around the average. At the wheels on a stock C7 is about 390-395 I believe.
Old Sep 3, 2017 | 08:56 PM
Cjunkie's Avatar
Cjunkie
This is correct. They dyno in the 380-390s STONE stock.
Old Sep 3, 2017 | 11:36 PM
joemosfet's Avatar
joemosfet
I've read manual transmissions will have less drivetrain loss than automatic transmissions.
Old Sep 4, 2017 | 04:18 PM
thrilled's Avatar
thrilled
mine was 410.I believe the automatic is around what you said.I added some goodies.Now I have 590 at the wheel.Approximately 40-50
more than the Z06.
Old Sep 5, 2017 | 04:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
This!!
True compression, cam specs etc. Still done today by many mfrs.....dont get hung up on dyno #s car will still run the same.
To Engine HP..need smart Gearhead!!!
Old Sep 5, 2017 | 09:56 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
In the past, some of GM's performance specifications seemed to have been written by the Advertising Department rather than by Engineering.
Old Sep 5, 2017 | 10:37 PM
rkj427's Avatar
rkj427
Pro Mechanic
true statement.......................... more a mechanical connection than a hydraulic connection
Old Sep 7, 2017 | 08:06 AM
Bill Dearborn
There was an art form to the lies though. Back in the day drag race classes were based on advertised hp to weight figures. GM seemed to have a knack for building lighter cars than Ford or Chrysler and lied less about HP. So a guy could go the strip in a stock 57 Chevy 2 Dr Hardtop with a 270 horse small block and completely blow away an 8 year newer Mustang with a 270 horse motor. It happened all the time.
Bill
