C7 headers intake safe without tune?
Old Oct 1, 2017 | 12:59 PM
Kohler717's Avatar
Kohler717
Default C7 headers intake safe without tune?
2015 stingray .I'm about to order kooks 2 inch headers and cattless xpipe, afe cold air intake, and a ported throttle body. I'm going to install all of this myself and then later have it professionally tuned. Will it be harmful to my car to drive around without a proper tune? Also does anybody have whp and torque numbers for this setup? 7 speed manual
Old Oct 1, 2017 | 01:03 PM
Kraz8s's Avatar
Kraz8s
Always get a tune ASAP, also 2in headers are a bit much if you aren't going FI.
Old Oct 4, 2017 | 11:27 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
No it is not safe to drive your car without a tune - way to lean...
We do have all Kooks and aFe instock and ready to ship...no waiting
Kooks
https://www.corvettepartsandaccessor...te-parts/kooks
aFe
https://www.corvettepartsandaccessor...o-dry-s-intake
Regards
Chip
__________________
..................Click for
Old Oct 7, 2017 | 02:45 PM
c5racr1's Avatar
c5racr1
Mine was rich, I had to lean it out.
Old Oct 7, 2017 | 08:45 PM
Ghostnotes's Avatar
Ghostnotes
For a short time you will be ok, again for a short time. Will probably end upsetting a few codes as well.
Drove my G8 that way for about a week,ran rich below 1500rpm.
Old Oct 7, 2017 | 09:39 PM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
Kyle, remember-if you get headers, as the guys said, it WILL require a tune. If you have to have the car tuned, it voids the warranty.
With you car being a 2015, this may not be an issue. But I wanted to make sure you knew, just in case.
Old Dec 24, 2017 | 09:24 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Car will run much better with a tune. You are short changing yourself not doing so.
Old Dec 24, 2017 | 09:32 AM
Kohler717's Avatar
Kohler717
The car is getting heads/cam package in a couple days. That’s when I get my tune. I installed the headers a couple weeks ago but I wasn’t gonna have it tuned for the headers then again for the cam package. I can definitely tell it doesn’t run the best right now without a tune.
Old Dec 24, 2017 | 09:34 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Can't wait till it gets finished ........... If there is such a thing.
Old Dec 25, 2017 | 01:32 PM
Poppacapp's Avatar
Poppacapp
Disagree. 2" headers perform well in a bolton NA application, and will make more power than the 1 7/8
Old Dec 26, 2017 | 12:20 PM
mittens's Avatar
mittens
I did the same thing and drove it for 2-3 weeks before Cam and tuned. Kooks headers no cats and AFE intake. it was fine... and was rich...
the car can make up for alot from the facotry.
Old Dec 26, 2017 | 05:35 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
You just drove with the check engine light on ?
Old Dec 26, 2017 | 06:31 PM
Internets_Ninja's Avatar
Internets_Ninja
Not on a stock cam LT1
Old Dec 27, 2017 | 01:00 AM
Poppacapp's Avatar
Poppacapp
I have stock cam in my Grand Sport, and with boltons only with 2" headers am currently the 2nd fastest Bolton C7 after checking the latest posts on the fastlist thread. I would say the 2" headers are performing fine.
I also have dyno proof from a 6gen SS to my car same day same dyno one after the other with the only difference being his car has 1 7/8" headers vs my 2" catted setup.. same tuner did both cars. I can post that if you need further proof of the power difference.
Old Dec 27, 2017 | 04:41 AM
Danengraham's Avatar
Danengraham
Seeing that is a different car, it’s not really “proof”. Cars can varry a decent amount, you could have been making 10-20hp more than him bone stock.From any of the test and comparisons I have seen, the difference is minor either way. Hell enginemasters beat a set of headers to death and collapsed almost all the tubes, still made almost the same power.
Old Dec 27, 2017 | 08:51 AM
mittens's Avatar
mittens
Yes, I did. I scanned it many times for lean codes or other issues over the course of that 2-3 weeks. as my cam/DOD parts came in and I was waiting. Only things that popped up where the missing rear O2s. I am not one to "deal" with a dash light....
But when I know the car was going to be completly taken apart in 2 weeks... and then tuned, hard to justify tuning it to make a light go away for 2 weeks. So I waited. Then we dynoed car for a semi baseline and it was Fat not lean with intake and headers... so it was fine the whole time. "Fine" being not hurting it, I am sure a tune would help it take more advantage of the parts... but again, in 2 weeks it was cam install time. I just needed to get the headers installed and I hated driving car so quite.
Old Dec 28, 2017 | 12:13 AM
X25's Avatar
X25
Sr.Random input generator
+1; 2" makes more power, but the gain is not too much, and you'd need to deal with fitment issues. Considering how close it also gets to everything else, I'd stick with 1 7/8" for a track car. For a street/drag car, however, it's not that big of an issue.
To C7 headers intake safe without tune?
Old Dec 28, 2017 | 01:57 AM
Poppacapp's Avatar
Poppacapp
Well, dyno results aside, I'll default to track results then.
Just a note... had ero issues with fitment on my GS with the ARH 2" setup. They fit perfect.
Old Dec 28, 2017 | 05:06 AM
Danengraham
Once again its a different car.
The dyno and track times are not going to show that the 2" headers are the soul reason it makes more power, or runs a faster time. Too many variables. Same car, same dyno, different headers, only change. Or repeat the results 5-10-50 times on other cars, a tuner or shop that does hundreds of these would be a good place to start.
I'm not saying 2" don't make more power. I'm saying to have "proof" you need to tighten up your control group.
Old Dec 28, 2017 | 11:12 AM
Poppacapp's Avatar
Poppacapp
Agree on control group. I guess I can edit my statement to "You will have zero problems running 2" headers on a stock cam, bolton car and be able to grab a spot at the top of the Bolton fastlist"
I have zero issues with low end torque as seen in a 1.55 60ft on stock converter. Top end is decent with a 125.6 trap. From what I can see based on the posts in fastlist thread only Carlos has gone faster in a lighter base car with 3.42 gears and weight reduction.
I like my 2" setup. I think others will be surprised how well they perform in a properly setup car. Fitment wise, I can only speak for the ARH 2" setup... and they fit perfect
