2014 Starting Issues- New Battery
Old Oct 2, 2017 | 06:41 PM
Zracer's Avatar
Zracer
2nd Gear
Default 2014 Starting Issues- New Battery
Hi All, Hopeful the resident experts can give me some direction on this one. OEM battery was going and wouldn't keep a charge. Just replaced with a local auto store (match OEM spec) and after placement- I cannot get the car started, let alone to even unlock. I have running light when I unlock/lock on the FOB- but nothing on the dash, etc.. Just hours before with old battery, the car would turn over and I would have all electronics. All wires seem be tight and not broken around the battery and even replaced FOB battery. Any thoughts?
Thank you kindly in Advance!
14 Z51 w/ manual
Old Oct 2, 2017 | 11:07 PM
RonC7's Avatar
RonC7
A few thoughts:
- There is a small ground wire that comes off the negative battery clamp. There have been a couple threads that mention this wire is kind of short and easy to break off. Loss of this ground can cause problems.
- My other question is if you had the parts store load test the new battery - I have seen new batteries off the shelf fail load test.
- Have you checked voltage at the battery on both sides of the fuses? At the front fuse block?
Good luck - I also have a 2014 but have not yet had any battery issues...
Ron
Old Oct 9, 2017 | 09:23 PM
Zracer's Avatar
Zracer
2nd Gear
Thanks Ron, appreciate it! After checking the voltage on both ends of the car- traced it back to the 350v inline fuse.
Cheers!
Old Oct 9, 2017 | 09:50 PM
RonC7's Avatar
RonC7
Glad you found the problem. Just curious if the fuse is available from a parts store or is it dealer only? I've never had to replace one.
Ron
To 2014 Starting Issues- New Battery
