Using the PDR, one can get the speed and lateral g forcevalues for a curve. By using Google maps or a track blue print, corner radiuscan be estimated. Using the equation for lateral acceleration, it seemspossible to calculate the max speed for a corner assuming a maximal lateral gvalue. Does this make sense? I realize there are a lot of assumptions here suchas surface, tire temps, banking of corner etc, but I am trying to get an ideahow fast I can go in different sections of the track without having to push tothe point of understeer.
You mention yourself there are many variables and you event forgot some, like your vehicle speed (aero). Beyond that, most turns aren't perfect circles. Late apex, early apex etc, are you on the gas hard, brakes hard, etc.
It's not just lateral acceleration either. You should follow the edge of the circle on the accelerometer. The goal is to get on the gas the earliest, not pull the most G's.
Further, lateral acceleration is a static measure. It doesn't take into consideration things like weight transfer when you're talking about the max.
These things aren't insignificant, nor do you take turn in a uniform circle, under constant load. There are turns my car registers at 1.4 Gs. There are turns where 1.4 G's would have me upside down in a ditch. There are days I can take a turn at 1.4 Gs. There are other days that same turn at 1.4 would have me spinning. Heck, it changes lap to lap depending on tire temp- which again is a big deal.
Just keep working on a few turns every session, gradually building up. While G is a fun stat, it's not very informative for how well you're taking a turn.
Thanks for thoughtful reply. I understand your points. What PDR info, other than lap times, would you use to help focus areas for improvement?
The actual video. Compare it to a video of someone really fast. Watch the difference in brake points, when they get on the gas, when they have the wheel straight coming out, when they start turn in, what lines they take, etc. Then watch yours.
You can look at your accelerometer too I guess- that can help to a degree. At the end of the day, driving isn't formulaic.
There is a really neat paper someone did like this from a bmw club on road america. It says you can take the kink at like 140 at 1.1 g's or something street tireish. Which if i survived would make me rich. Extrapilating the pucker factor at 105 to 140 would definately cause diamonds to be created in my butt.
Other then the kink and bill mitchel its actually pretty realistic though.
That isn't the actual one but I believe its possibly a variant of it. The sheet i am thinking of is more or less this same sheet but it has 1.0 1.1 1.2 1.3 1.4 g's corner speed using the donohue formula labeled at each corner in the printout.
I would suggest queuing up a couple of your faster laps in the Cosworth toolbox (either the GM one or the more features Pi toolbox) and look at the time delta. Find where each lap is respectively quicker and try to understand why. I've found that speed, accelerator, and brake are the most useful for this. Now try to take those best aspects of multiple laps and combine them in to one lap. This thread I walk through exactly that process comparing my fastest lap with Bill's. https://www.corvetteforum.com/forums...i-toolbox.html
As far as lateral G's are concerned, I've not found that terribly useful but I've seen some pro coaches using G Sum to help a driver know whether they could go faster through a given corner. As others have noted though you can't expect to get to the same limit in each corner but it gives you an approximation. G Sum is just the total of lateral and longitudinal G's added as the absolute value of each.
