Procharger - 6.2 stingray 3LT
Old Oct 9, 2017 | 09:12 PM
Enemy7's Avatar
Enemy7
Default Procharger - 6.2 stingray 3LT
Anyone have any issues when installing a Procharger? Pros or Cons?
Old Oct 9, 2017 | 11:26 PM
kc stingray's Avatar
kc stingray
installed a p1x on labor day weekend. so far so good
Old Oct 10, 2017 | 06:20 AM
Enemy7's Avatar
Enemy7
KC, are you happy with the HP gains?
No overheating issues or Check engine light issues?
Old Oct 10, 2017 | 09:44 AM
C7&7's Avatar
C7&7
Hey man I see you're in Sachse. I also live in Sachse. Shoot me a text you can come take a ride in mine that is supercharged (well and a lot more). Your mind will be made up. 214.882.8271
Old Oct 10, 2017 | 11:52 AM
blown81bu's Avatar
blown81bu
Just did a P1x kit on a stingray....used the procharger can tune too
car is spot on and fast
Old Oct 10, 2017 | 08:06 PM
BrunoTheMellow's Avatar
BrunoTheMellow
go look on forced induction section. Many of us have done it will a lot of documentation.
Old Oct 10, 2017 | 08:55 PM
kc stingray
check engine light turned on and cooling fan was going crazy after install. this is a known issue
with the mas airflow extension. make sure prior to install all pins are installed and not bent. i used the extension from my cold air kit while i waited for a new one from procharger. at first i used the canned tune,then went to a custom tune. glad i did! my car is an a8 and i started to have issues. transmission didn't feel right. turns out procharger does not change the tcm tune at all. also while tunning found out as iat rise car was not pulling timing. very scary! in the end i am very happy. skip the canned tune and find a tuner you can trust and you will be set. i do recommend upgrading to the p1x. upgrade cost is minimal and worth it. hope this helps.
Old Oct 12, 2017 | 10:27 PM
LT1pwrd'94's Avatar
LT1pwrd'94
I'd like to check out your car when I get mine back if that's ok...I'm in Forney.
What's your setup?
Old Oct 13, 2017 | 07:51 AM
Enemy7's Avatar
Enemy7
Old Oct 13, 2017 | 07:52 AM
Enemy7's Avatar
Enemy7
What's your setup?
i went to look at his car... it is definitely BAD ***!!
Old Oct 13, 2017 | 12:09 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Was just thinking about doing this.. >
-Josh
Old Oct 13, 2017 | 01:43 PM
Junox's Avatar
Junox
Man, I would love to see this car in person too! I'm in Carrollton. Thanks
To Procharger - 6.2 stingray 3LT
