Eco mode
Old Oct 10, 2017 | 09:47 AM
ZXZOOMER's Avatar
ZXZOOMER
1st Gear
Default Eco mode
Is there a way to disable the cylinder shut down on my 2015 C7? My car is an automatic , not sure if has any bearing.
Old Oct 10, 2017 | 10:24 AM
TorchZ51's Avatar
TorchZ51
It can be disabled in the tune.
Old Oct 10, 2017 | 01:54 PM
astaggs's Avatar
astaggs
Yea get a Range AFM controller and corded switch
Old Oct 10, 2017 | 03:53 PM
mcoomer's Avatar
mcoomer
I believe that driving in Manual Mode will prevent it from going to V4. Can someone confirm this?
Mike
Old Oct 10, 2017 | 05:52 PM
BRCC's Avatar
BRCC
Mike
Yes, manual mode will disable V4 but you must paddle shift to change gears.
Old Oct 12, 2017 | 06:09 PM
IM4A2Z's Avatar
IM4A2Z
I believe I saw on a chart listing all the options that are changed when the Mode dial is switched between Weather, Eco, Tour, Sport and Track that Eco is the only mode that will allow cylinder deactivation.
Old Oct 12, 2017 | 06:20 PM
NSC5's Avatar
NSC5
For a manual transmission eco is the only mode that will allow V4 operation but with the automatic V4 is enabled in any mode. Putting the A8 into manual mode will prevent V4 operation UNLESS you select eco mode and in that setting it will still go into V4 with the transmission set to manual.
To Eco mode
