Basic stats: 416, YSI, Fuel System, Circle D, 8l90. My car has always pulled 10* + timing (through torque management) when it hits 5500rpm in first gear, causing the car and RPM's to lower/slow down. It will also do it sometimes in 2nd and 4th. Attached is a log showing what I mean. Any info on what it could be? I don't want to turn torque management completely off and grenade the trans.
Perhaps your torque demand tables do not reflect your mods. I've seen LS/LT motors go so far as closing the throttle blades. It's not torque management to save the trans, it's torque modeling for the calibration. If not updated, the engine will be able to produce more torque than planned and will actually reduce torque output (by timing and then throttle) in order to compensate.
Let's say your motor in stock form made 450 lb-ft of torque at 5500. Now all of a sudden due to your mods it's making 550. It knows this and will try to scrub off 100lb-ft to get back to the torque target.
Just a hunch until a knowledgeable tuner comes along to chime in!
I appreciate the feedback. I tried to log every predicted and actual torque I could find in the scanner. My predicted and actual torque seems to be nearly dead on, which is why I don't understand the huge timing pull. Would that be in the Virtual Torque/Coefficient tables? I tried to adjust the virtual torque at 800mg airmass (which it always sees well more than that) and it was still doing the same.
Are you logging pedal position and actual Throttle position as well? If so, do you have any discrepancies there? Again, that would be a function of driver demand and commanded torque. I would post logs and the tune, hopefully T/A Kid and/or Higgs will take a look and chime in
I logged Pedal position, desired throttle, and throttle position. Desired is at 100% and Throttle is at 99.6% while it pulls.
Timing drop is coming during shifts. Looks like you are spinning also. Immediate Engine torque source is Trans S. I am not an expert though... still learning this stuff. Shifts look a little long also.. but I have TM dialed out on mine.. so hard to compare.
To me, it looks like it starts pulling timing down to 4* @ 5350 in this log, then timing comes back for a split second at the shift, then pulls timing again for the shift. It then comes back full in 2nd then does it again slightly after 2nd.
With TM dialed out, will it still pull timing on the shift to help the trans out?
I'll defer to the more experience guys. But it looks to me like you started to spin in that area. Your Torque Management advance is kicking up to 11.2 degrees in the shift area too... possible from the wheel spin?
Did you zero out the Accel based rev limiting? It can pull power to slow down revs if it thinks they are too fast.
Can mods really cause a car to accelerate fast enough to trigger that one? I wonder why they care about that, to prevent overshooting the rev limiter?
Back in the Gen 2 LT1 days I had to fix/workaround a bug in that ancient ECM where it'd fail to upshift the trans if the wheel speed sensor value was changing too quickly (ie: accelerating faster than they expected possible). Seems similar, though that was a "bug" and this is a "feature".
Close to 1 year. Back when it had slightly less boost and less timing, it
seemed alrght in the logs. Within the past year with more boost and the 116 ignitor/slightly more timing, it’s always done it.
it was under Cutoff/DFCO but they rearranged the tabs and tables on the Beta recently so I would have to look at it to see if it is still in the same place.
