4-pinion C7 diff write-up
Old Apr 6, 2018 | 09:51 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Originally Posted by rflow306
I agree your way with the 4- C6 spiders, shaft and the rod bushing is the strongest. I think drilling the C6 spiders leaves very little material on the top part of the spider.
Originally Posted by JHEBERT
Exactly, it weakens those 2 gears...
So you think the 4 C6 spiders and shafts are stronger than 4 C7 spiders and shafts?
Old Apr 6, 2018 | 09:57 PM
JHEBERT's Avatar
JHEBERT
No, the 4 c7 spiders are optimal, because they have the correct tooth profile for the side gears. More of the tooth is in contact at any given time
What I meant was that IF you are using c6 spiders, better to use 2 c6 pins and bush the carrier
John
Old Mar 2, 2019 | 04:57 PM
ACS55's Avatar
ACS55
Anyone find a part # or source for the C7z spider gears?
What about the improved 2019 spider gears?
thanks!
Old Mar 3, 2019 | 11:33 AM
JHEBERT's Avatar
JHEBERT
As of last week, no availability on c7 spiders or c7zr1 (all 2019) spiders to even compare.
I do have a 2-series carrier for sale as well as a complete 2.41 elsd removed from my car when I did this build on a 2.73 that I’m using now.
Old Mar 4, 2019 | 05:30 PM
ACS55's Avatar
ACS55
Are all of the C7 spiders the same?
I have a base model/auto/2.41 differential located locally for only $500, that i would like to use the spiders & cross-pin out of to do the 4-spider conversion on my 2016 c7z/a8.
At 750/760 RW, would it be advisable to change ratio to 2.73 or keep the 2.41, for 1/4 mile?
Thanks!
Old Mar 26, 2019 | 02:04 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Old Aug 2, 2019 | 02:55 PM
Thomasmoto's Avatar
Thomasmoto
Old Aug 3, 2019 | 09:40 AM
ACS55's Avatar
ACS55
Update:
I ended up going with the RPM wavetrac & DSS stub axles, & DSS CV axles. I kept my 2.41 ELSD differential.
After I sent my differential to RPM, they ran out of DSS stub axles... because the machine that makes the axles at DSS was broken... my luck.
I ended up waiting 11 weeks before we could finally get the DSS stubs, and RPM could complete my differential and return it. I'm now in the process of putting it back together and should be up and running this week.
It's been a long hot summer, so it's not much fun drag racing in 100 degree weather here anyway.
Thanks!
Old May 8, 2020 | 11:02 PM
3LZ CARBON Z's Avatar
3LZ CARBON Z
1st Gear
Update:
How's it working out for you?
Old Feb 8, 2023 | 09:27 PM
T/A KID's Avatar
T/A KID
Any more update on this??
Old May 3, 2024 | 11:02 PM
lsxorsak's Avatar
lsxorsak
1st Gear
Now we are getting somewhere
More c7 spiders, now we just need our stub shafts to arrive from RPM.
Ant is drooling I’m sure, as I’ve already sent pics to him
are you still using this setup?
Old Jan 19, 2025 | 10:25 PM
vB1OS's Avatar
vB1OS
7th Gear
I cannot find C7 ZR1/ Z06 spider gears anywhere. The 2014 part number says discontinued. It is my understanding that GM redesigned the spider gears in 2019. Would anyone happen to have parts to complete this mod? Or who would I talk to in getting this done? Thank you
Old Feb 5, 2025 | 02:14 AM
  #33
timcgs's Avatar
timcgs
5th Gear
Any luck finding spider gears or equivalent? I'm currently trying to source a used diff to build from it's side carrier spider gears. I would think there is another common gear on the market that would fit with minimal machining... These cars are not that old.
