Performance data recorder retro fit ?
Old Nov 6, 2017 | 08:02 PM
Adix's Avatar
Adix
4th Gear
Default Performance data recorder retro fit ?
I have a 2016 and 2017 2lt stingray
if if I get a hold of the parts....
can I retro fit the performance data recorder ?
The dealers are clueless..
Old Nov 6, 2017 | 09:07 PM
dmaxx3500's Avatar
dmaxx3500
a quick answer
''NO''
Old Nov 6, 2017 | 09:33 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Originally Posted by dmaxx3500
a quick answer
''NO''
This is correct. Cannot be retrofitted. The car itself does not contain the wiring in the harness to add it in.
Old Nov 6, 2017 | 10:24 PM
Adix's Avatar
Adix
4th Gear
[QUOTE=FYREANT;1595916525]This is correct. Cannot be retrofitted. The car itself does not contain the wiring in the harness to add it in.[/QUOTE
Bummer -Thanks for that info .. would you know what month and year the data recoder was started in production ? 9-2016 ? I need to start shopping for a used lt3 vette with the recorder/
Old Nov 7, 2017 | 06:55 AM
Poor-sha's Avatar
Poor-sha
Track Rat
Its available in all 2015+ models as an option.
Old Nov 7, 2017 | 08:25 AM
dmaxx3500's Avatar
dmaxx3500
''NO'' ,is a big word,
if you had a GM factory service manual,time,wire,and every part, a PDR needs,,you could add it,but it would need factory programming,probably could get done
To Performance data recorder retro fit ?
