Cooling fan won’t shut off And temp gauge not working
After driving a few miles the fan keeps running when the car is shut off and also my temp gauge doesn’t work when this happens. When it happens, I disconnect the battery and it all goes back to normal but a few driving cycles then it starts happening. Any ideas would be gladly appreciated.
Are you running a 160* thermostat? If so, just let it run and heat up for a minute or so before jumping up to freeway speeds. It isn't coming up to temp as fast as the computer expects and sets a "coolant undertemp" code. If you tune the car you can turn that code off.
If you are running a stock thermostat it may have failed open.
Fan Runs After Engine Shuts Off
The fan is designed to run after the engine is shut off under certain conditions but it appears you might have different conditions (possibly introduced by the tune?).
https://www.corvetteforum.com/forums...post1595925872
Fan Keeps Running
It might be worth checking for DTCs and/or checking for temp sensor issues. By disconnecting the battery you could be temporarily dismissing a code that reappears after a few start/stop cycles. A GM scanner should show a code history. Did your tuner modify any cooling fan settings?
I had similar symptoms. The retaining clip to the temp sensor (below the throttle body, driver side) had cracked and the connector wiggled its way loose. Was very random because it was an electrical connection, so sometimes it would happen sometimes not. Id think a rubber gasket going bad would eventually cause the problem all the time. Might be worth checking that connector
As I pulled into work this morning I noticed the coolant fan was running on HIGH and looked down and my temp guage is DEAD.... Shut car off and fan is still running... I guess a trip to dealer is in order here? Hoping extended warranty covers whatever it is.
Received 1,298 Likes
Sounds like a temp sensor issue. When the temp does not read, the car's computer makes the safe assumption that the car is hot and runs the cooling fans on full and cuts loads like the A/C compressor. Fault codes would confirm the problem.
Ron
Ron
Received 8,928 Likes
Bill
