Do Z06 ARH Headers fit on Z51?
Someone local with a LT4 Z06 is selling a set of ARH long tube headers. I have a LT1 Z51. Anyone know if they are the same? Thanks - Mike
I built an extension harness and cut the valves out of the stock pipes and mounted the valves, and 3 inch section in the fender well. I track my car and didn’t want to burn them up. I did have to do a tune because the exhaust not sounds absolutely horrible in v4 mode so that was disabled. Btw with long tubes you will need a tune, it runs rich in the low rpm range and lean in the upper range.
