Valve spring compressor.
Old Nov 22, 2017 | 05:05 PM
Ghostnotes's Avatar
Ghostnotes
Default Valve spring compressor.
Anybody have a recomendation on a valve spring compressor that will work for these heads??
Thanks.
Old Nov 22, 2017 | 09:44 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
https://vengeanceracing.net/2014-c7-...ompressor.html
Old Nov 22, 2017 | 11:02 PM
Ghostnotes's Avatar
Ghostnotes
Ok thanks, I'm familiar with this and had it in mind but was not sure if it worked on an LT.
Problem solved.
Got a total of about 8 hours into it "learning"my way through it.
Only thing i took off was the intake to get it out....not too bad over all. I left the grounds on untill i seperated it, made it much easier, there is enough slack. I lowered the cradle a little to gain a little more access to the rear tranny bolts....helped a lot which then gave me extra room for lossening the motor mounts because i then had some extra lift to get a better angle on the lower bolt coming through the frame.
Old Nov 23, 2017 | 07:10 AM
Ghostnotes's Avatar
Ghostnotes
What about a clutch alignment tool?
I tried gen 5 6.2 and c7 but nothing comes up.
Old Nov 23, 2017 | 08:12 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I bought a Mantic Twin clutch and flywheel kit in order to get my clutch alignment tool lol
Old Nov 23, 2017 | 08:27 AM
Ghostnotes's Avatar
Ghostnotes
Might give them a call after thanksgiving and see if they have the individual part.
Thanks!
Old Nov 23, 2017 | 08:45 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Thanks!
I believe they are in europe with no 800 number..
Old Nov 23, 2017 | 09:34 AM
Ghostnotes's Avatar
Ghostnotes
Outsourcing at its best.....
Might just have to wait to see if dealership carries them. No need replacing my clutch yet, almost no wear and will be below 800hp......for now.
Old Nov 23, 2017 | 09:43 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Its not outsourced actually.. thats where Mantic is actually located lol
Old Nov 23, 2017 | 12:26 PM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
What about a clutch alignment tool? If you use a C7 or Z06 OEM clutch You will not need a alignment tool but I don't know about the after market clutches.
Old Nov 23, 2017 | 02:20 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Why wouldn't you need one with an OEM clutch?
Old Nov 24, 2017 | 11:46 AM
sammy burks
The Z51 & Z06 has the twin disk clutch which will self center its self so you will not need a alignment tool
To Valve spring compressor.
