X pipe question
Old Nov 22, 2017 | 10:52 PM
jimmy3293's Avatar
jimmy3293
Default X pipe question
I was thinking about putting an X pipe with cat delete on my 2017 grand sport for a little more sound. But I am concerned that the exhaust will have the strong oder with just the primary cats. Has anyone had this happen with just the primary cats on?
Old Nov 23, 2017 | 12:49 AM
LT4CMG's Avatar
LT4CMG
I smell nothing different before/after my Corsa Xpipe swap. Now, not sure if the guy losing the race smells anything different behind me, but I certainly don't. Obviously it takes a couple days for the oils and stuff to burn off the new pipes, otherwise all good
Old Nov 23, 2017 | 10:06 AM
JHundertmark's Avatar
JHundertmark
Agree with Is3zob except that my experience is with Borla X-Pipe. No change in odor & no code issues on 2016.
Old Nov 23, 2017 | 10:17 AM
RubiconVette's Avatar
RubiconVette
Old Nov 23, 2017 | 11:14 AM
Gary barnes 1098's Avatar
Gary barnes 1098
Got borla,absolutely love it!!! And I'm ****!!
Old Nov 23, 2017 | 11:48 AM
VictorBarron's Avatar
VictorBarron
I say go Corsa, music to the ears.
Old Nov 23, 2017 | 12:38 PM
Internets_Ninja's Avatar
Internets_Ninja
I just put the Borla X pipe on mine that deletes the secondary cats. Aside from a little extra smell in the morning before the primary cats warmed up, there is zero odor. The Primary cats do a great job. No need to worry about any smells.
sound is AMAZING
Old Nov 23, 2017 | 02:12 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
No difference in smell. Most of it comes from the primary cats. I have deleted the secondary and no hint of gas.
Contact us for the Borla or Corsa.
We have the best pricing on the forums!
-Josh
Old Nov 23, 2017 | 09:20 PM
L82Brake's Avatar
L82Brake
No, none here.
Old Nov 23, 2017 | 09:58 PM
rcharles30's Avatar
rcharles30
None here with the Corsa
Old Nov 24, 2017 | 12:12 AM
TSLAVette's Avatar
TSLAVette
Anybody dyno pre and post x-pipe install? Don’t want to lose HP or TRQ.
Old Nov 24, 2017 | 12:53 AM
MAXXPSI's Avatar
MAXXPSI
and no cel?
Old Nov 24, 2017 | 01:25 AM
LT4CMG's Avatar
LT4CMG
Absolutely no CEL for me or 2 other c7 buddies. These are only secondary cats, nothing to worry about. (And I have terrible luck, so if no CEL for me, chances are you’ll be fine)
Old Nov 24, 2017 | 01:50 PM
MarkRacerX's Avatar
MarkRacerX
I've heard +5whp/TQ range, nothing huge but all adds up and with a little more growl! You won't have a CEL since the o2s only monitor the front main cats on downpipes.
Old Nov 24, 2017 | 02:01 PM
MerakiAutoworks
Supporting Vendor
No CEL either.
-Josh
Old Nov 24, 2017 | 03:34 PM
madrob2020's Avatar
madrob2020
As someone else sorta pointed out, you will get a very strong smell of the oils/coating of the pipe for several drives of going thru the heat/cool-down cycles. You'll come to a stop & you or the guy next to you might think somethings burning under the car for a short week or so! I also wrapped mine with heat tape before install & some of the smell could have been more from it tho.
Old Nov 25, 2017 | 04:40 PM
jimmy3293's Avatar
jimmy3293
thanks everyone
Old Nov 29, 2017 | 09:48 PM
johnc9909's Avatar
johnc9909
Cruising
Originally Posted by jimmy3293
thanks everyone
Yeah no problems here either with borla x pipe. You will notice the biggest sound difference under hard acceleration. I also pulled fuse 42 if you have dual mode exhaust which will leave valves open all the time.
To X pipe question
