Error P26C5
Old Dec 4, 2017 | 08:24 PM
Stingray_Z06's Avatar
Stingray_Z06
4th Gear
Default Error P26C5
Hi folks,
i am pretty new to this forum and wanted to know what this error code was ( i read something with fuel pump A low /performance )
So far the car runs fine and after I clear the code every time i start the car it is again in the memory
somebody has an idea
thanks dani
Old Dec 5, 2017 | 11:17 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Is the car modified with an aftermarket tune? Are you still under warranty?
the code P26C5 is for "Exhaust Flow Control Valve Control Circuit". It has to do with the valves in the exhaust system. Did you pull any fuses recently?
Old Dec 6, 2017 | 04:33 AM
Stingray_Z06
4th Gear
Hy FYREANT
thanks for your info,
I just installed a mild to wild remote and a Borla x pipe. So far nothing felt during driving. I just wanted to tune the engine with Hypertechs ME2.0 where i read this code. But in zhe Programmer they said it was somthing with "fuel pump A pressure low/performance" maybe GM has several uses for this code. Youre sure with the Z06 this code is related to NPP exhaust valves ?
The code is produced when I just launch the car without starting the engine
thanks again.
Dani
Old Dec 6, 2017 | 06:44 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Originally Posted by Stingray_Z06
Hy FYREANT
thanks again.
Dani
What is hypertechs 2? Is that some off the shelf thing? Im not familiar with that tuner. Yes, im certain as I read it in the factory service manual. Its a B level code so you should be able to start the car and not have a a check engine light illuminated. You will still throw the code, but its a "B" level code so you won't see it on the dash. You don't have to worry about it.
Old Dec 10, 2017 | 06:03 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Here's you answer:
https://www.corvetteforum.com/forums...s-b-level.html
To Error P26C5
