Please Help!!! Limp Mode 4th Gear C7 Corvette A8
Old Dec 6, 2017 | 07:22 PM
C7_Juan's Avatar
C7_Juan
Navigator
Default Please Help!!! Limp Mode 4th Gear C7 Corvette A8
So I snapped my input shaft on my transmission. I got that repaired. Once we turned on the car I got a CEL so I immediately turned it off then the code it threw was P07BF - input speed sensor circuit low voltage .. so we took off the tranny again and changed the only sensor that we thought was it which was the Output speed sensor.. put it back together and nope still same problem and throws the CEL and 4th Gear Limp Mode... called the dealership to see once again if they had a Input speed sensor and nope they said the C7 don’t have one other then the Output sensor and speed sensors on the wheels (called 3 different dealers) please help!!!
mods:
Texas Speed headers & X pipe
E85 Fuel
Cam & Cam kit
Hp Tuners tune
AFM delete etc ...
Old Dec 8, 2017 | 11:05 PM
Jetblackc6's Avatar
Jetblackc6
mods:
E85 Fuel
Cam & Cam kit
Hp Tuners tune
AFM delete etc ...
trans does has 3 speed sensors, input, intermediate, and output. they are located under the valve body.
Old Dec 9, 2017 | 10:59 PM
C7_Juan's Avatar
C7_Juan
Navigator
Default Update
So I did find out that the out put sensor is together with the input and we changed all three but nope still same problem saying low voltage ..
Old Dec 10, 2017 | 01:25 AM
383vett's Avatar
383vett
Since it started right when the axle broke, did you try clearing the code to see if it goes away?
Old Dec 10, 2017 | 01:32 AM
tekhombre's Avatar
tekhombre
mods:
E85 Fuel
Cam & Cam kit
Hp Tuners tune
AFM delete etc ...
It may also be the connection to the sensor.
Old Dec 13, 2017 | 11:52 PM
C7_Juan's Avatar
C7_Juan
Navigator
Default Reply
Yep. So when the car is in the lift we clear the code and it’s perfect normal but exactly 5 seconds later throws CEL and Limp Mode
Old Dec 13, 2017 | 11:53 PM
C7_Juan's Avatar
C7_Juan
Navigator
Default Reply
Going to have it check out again this weekend, thanks though
Old Dec 14, 2017 | 06:51 AM
NSC5's Avatar
NSC5
All of this sensor data runs to the TCM so check the main harness connector itself at the transmission (and at the TCM if you unplugged it there) to make sure a contact wasn't damaged during connector install. Of course the separate sensor harness connectors could also be the problem.
You may find the photos and information here useful: http://www.atra.com/Webinars/GM/8L90_Introduction.pdf
Old Jan 16, 2018 | 10:37 PM
C7_Juan's Avatar
C7_Juan
Navigator
Default No fix yet bummer
Been two months already and no fix yet//:Havnt found the solution ....
Old Jan 17, 2018 | 11:41 AM
laserdude2215's Avatar
laserdude2215
So did you measure the signal voltage? The reference voltage? What were the results?
Old Jan 17, 2018 | 07:48 PM
JHEBERT's Avatar
JHEBERT
Something else not right, and you can bet it's related to the input shaft failure or it's replacement. Something has been overlooked, be it unseen damage or faulty component replacement. I do feel your pain, I would like to see components if you tear it down again.
Old Jan 17, 2018 | 08:43 PM
Drew27's Avatar
Drew27
Did you do a trans relearn?
Old Jan 18, 2018 | 05:46 PM
C7_Juan's Avatar
C7_Juan
Navigator
Default Update
Yes and all the voltage is good.
Old Jan 18, 2018 | 05:48 PM
C7_Juan's Avatar
C7_Juan
Navigator
Default Update
Yes we did in fact we reprogrammed the input sensor output sensor and the intermediate sensor and nope not good enough still saying input sensor low voltage
Old Jan 18, 2018 | 05:50 PM
C7_Juan's Avatar
C7_Juan
Navigator
Default Update
So yes, the transmission is getting tear down once again and hopefully they find something
To Please Help!!! Limp Mode 4th Gear C7 Corvette A8
