Squeaky brakes
Old Dec 12, 2017 | 11:21 AM
sbiesman's Avatar
sbiesman
3rd Gear
Default Squeaky brakes
Good morning all- -so, I have read dozens of comments about this brake problem so no need to repeat or summarize here.
I have a 2015 Stingray (purchased new April 2015) with 6800 miles on it and the squeaky issue has been with me forever! I am going in for a routine oil change in the next week or so & thought I would ask/demand GM replace the brakes.
Bad/good strategy?? What do u think?
Thanks very much.
Sherwin
Old Dec 12, 2017 | 11:42 AM
Moving this to C7 Tech.
Old Dec 12, 2017 | 12:27 PM
Maxpowers's Avatar
Maxpowers
As a first step, they'd likely add some synthetic lubricant to the back of the pads before replacing. What model is your C7. You might consider changing to low dust ceramic pads unless you track a lot.
Old Dec 12, 2017 | 05:54 PM
Bill Dearborn's Avatar
Bill Dearborn
Good brakes squeak. I don't care if the brakes squeak unless they are screeching so loud they hurt my ears (I have had some race pads that are that loud).
Bill
Old Dec 12, 2017 | 08:17 PM
rrsperry's Avatar
rrsperry
Since I have no idea how you drive, I’ll give you a wild *** guess. Go use them, go use them hard. The car is 2.5 years old and only 6500 miles, I’ll guess you just don’t use them hard enough.
Old Dec 13, 2017 | 01:56 AM
mcoomer's Avatar
mcoomer
I wonder, have you bedded the pads? Getting some heat into the pads, calipers, and rotors could clear this up, and give you better braking performance.
Mike
To Squeaky brakes
