GS 1/4 mile data
Old Dec 14, 2017 | 07:37 AM
Ramler's Avatar
Ramler
Default GS 1/4 mile data
What is considered good data for 1/4 mile runs in a bone stock 2017 Grand Sport. Using the PDR as a timer I have only done 2 runs.
0-60----4.0
0-100--8.7
1/4----12.2
This is with no burnout and temp. at 34 degrees. Tires were warm but I realize with that temp. traction is not good. Trap speed was about 121, again using the PDR.
I would just like to know what I can expect when the weather gets better.
Thanks.
Old Dec 14, 2017 | 07:46 AM
lakemg's Avatar
lakemg
ironman77 knows of a stock one running 11.50s. I've personally seen a stock 14 Z51 run an 11.70 in reasonably good weather (low DA). I haven't run my '15 Z51 yet, but I swear it feels like it's a second faster than my old souped up Pontiac G8 GT that ran a best of 12.26 so I'm pretty sure that mine will dip well into the 11's. These cars are crazy fast for being stock...
Old Dec 14, 2017 | 08:07 AM
punky's Avatar
punky
Banned Scam/Spammer
I hope the GS runs 11's as the 2018 Mustang GT runs right at 12 flat and nearly 120 MPH, everything is fast now. My daily driver AWD Cadillac will do low 13s, crazy.
Old Dec 14, 2017 | 07:02 PM
BJ67's Avatar
BJ67
You will have less trap speed in warmer temps and a slower et. If in the warmer temps your 0-60 improves, the ET will probably be the same. Under normal conditions, getting the car to run 12.0 is a job well done. Ignore trap speed, concentrate on great 60ft times when at the track and your et's will drop.
Old Dec 15, 2017 | 09:03 AM
bigsapper's Avatar
bigsapper
Fast list is pinned to the top of this sub-forum.
Old Dec 15, 2017 | 10:08 AM
BJ67's Avatar
BJ67
0-60----4.0
0-100--8.7
1/4----12.2
Thanks.
You didn't mention, automatic or manual trans.
Old Dec 15, 2017 | 10:21 AM
383vett's Avatar
383vett
PDR times are very inaccurate. Gotta take it to the track.
Old Dec 15, 2017 | 11:01 AM
Ramler's Avatar
Ramler
Auto
Old Dec 15, 2017 | 11:33 AM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
My 2014 A6 Z-51, totally stock.
Old Dec 15, 2017 | 12:40 PM
Poppacapp's Avatar
Poppacapp
The Grand Sport is heavier than the Stingray. I managed 12.20@115 bone stock in +3500ft DA(97 degrees) in my GS. They respond very well to boltons/E85 however.
Old Dec 15, 2017 | 10:14 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The list was most recently updated a year and a half ago, the stock section didn't have any GS at all.
I'm sure someone has a GS that deserves to be in the list, but it's not there yet.
You can read through all 700+ posts and see what you find.
GM claims the GS is quicker 0-60 than a Z51, I don't think the extra weight/drag would be enough to put it behind at the end of the quarter. But I've believed for a long time that the GM factory numbers come from the marketing department rather than the engineering department.
To GS 1/4 mile data
