Tach and shift light wrong with new thermostat?
Old Dec 16, 2017 | 12:32 PM
mittens's Avatar
mittens
Default Tach and shift light wrong with new thermostat?
Did a cam swap and while doing so a 160 thermostat... Car stays 165 on interstate and comes and goes warmer at red lights and stuff. Ok cool.. the tune has it marked as a 160 thermostat so no codes from it not getting to full temp/190 and the fans are adjusted as well.
BUT THE TACK. I keep it in sport mode most the time and it shows the red line where it changes when cold. And this also moves where the factory shift lights come on... the car at normal temp is now 165. The tach and shift lights are messed up thinking the car is cold.. so is there a fix somewhere else in the tune? Or do I just have to go back to factory thermostat?
Old Dec 16, 2017 | 01:34 PM
Bill Dearborn's Avatar
Bill Dearborn
What is your oil temperature when you are running at 165 on the interstate? There is a certain floor where most track drivers believe the oil isn't warm enough to support driving the car harder or going to extended WOT operation. GM may have set the tach warnings/settings to trigger off the oil temperature. We definitely know they put the car in limp home mode if oil temp exceeds 300+ degrees so they may have decided to use oil temp to advise the driver when the engine is warm enough to start pushing hard. You may have to run the car at speed in 4th gear instead of 6th or 7th to get the rpms higher to bring oil temperature up.
Bill
Old Dec 16, 2017 | 01:51 PM
davepl's Avatar
davepl
You've changed to a lower thermostat.
The engine coolant is now cooler (sometimes).
The engine oil is now cooler.
The tach will say shift earlier because it thinks the car isn't warmed up yet.
Old Dec 16, 2017 | 08:30 PM
mittens's Avatar
mittens
I am fully aware of why the car is doing it. It’s cooler and the car is acting like it’s cooler.. My question is, is there a way to adjust this part? Just like you can adjust the temp the ECU looks for it to reach as full operating temp? and to not toss a code that it won’t warm up.
Which is set and why no codes on my car... and the fans work as well. But will the tach and shift lights always be wrong?
Oil temps 170 on highway. When Car is 165. So oil is warm enough to do its job.
Old Dec 17, 2017 | 10:39 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Originally Posted by mittens
I am fully aware of why the car is doing it. It’s cooler and the car is acting like it’s cooler.. my question is, is there a way to adjust this? Just like you can adjust the temp for the code that it won’t warm up. Which is set and why no codes... and the fans. But will the tach and shift lights always be wrong?
I believe you can adjust that in the tune. Who's tuning the car?
Old Dec 17, 2017 | 11:57 AM
davepl's Avatar
davepl
Sure, fix the tune. You changed the thermostat without telling the car.
Honestly, I think the gains from a thermostat are chimerical and I'd put the factory one back in if it were me, but you can update the car to compenstate if you like.
Problem is, I don't know if the RPM shift decisions and that stuff are really controlled by the ECM or if it's the BCM or some other module (whatever is displaying the shift light, for example).
My guess is those assumptions about "how cold is too cold" are probably baked into the other modules. I doubt they're configurable by engine, but you never know.
In other words, I think it'll be a LOT of work to get everything to reflect your new operating parameters.
Old Dec 17, 2017 | 12:08 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Pretty sure mine is updated in the tune and was NOT a big deal. My car thinks its too cold until I get to ~165*. Then its fine. I've been meaning to go in and change it to 160 but haven't had the time..
Old Dec 17, 2017 | 12:47 PM
Flame Red's Avatar
Flame Red
FWIW, I first tried a 180 stat, and now I am running a 170 stat.
As the others have stated, unless you are willing to do a tune, and void your power train warranty, the fans will only come on above 190, so in traffic and hot weather, your engine will not run much cooler.
But I did not experience any of the above described issues. No codes, no messages, no warm up issues.
Old Dec 17, 2017 | 04:54 PM
mittens's Avatar
mittens
While I appreciate responses some of the responses are like they did not read the thread.
Where is this adjusted? The tune has the thermostate peramiroer set to 160. That’s why no codes as I stated before. And the car is tuned I am not worried about a warranty I just finished a cam install and DOD delete... so far from that.
So if you have lower thermostat, and your tach does not show it being cold. Please let me know how and where to adjust. Because the normal spot is done already and yet Car thinks it’s cold
Old Dec 17, 2017 | 05:47 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Simmer down, Mittens. Im not trying to pick a fight, but go back and reread your posts. You ask "CAN this be adjusted?" Not, "Exactly where do I go in the tune to change this?". I know the car is tuned, you specified this. I did not see you answer this so I will ask again, who tuned the car? You probably need to have your tuner sift through the billion settings in the tune to see where it needs to be changed.
If YOU tuned the car, well then that I can understand if you are asking because you don't know where it is. I don't officially remember where the setting is, just that I am pretty sure its there. Like you, I'd have to dig through HPT looking for it..
Ant
Old Dec 18, 2017 | 08:36 AM
6Speeder's Avatar
6Speeder
Ant
My car does this also (with a 160) and I would like to know IF this is adjustable, and where in the tune I would find it.
Old Dec 18, 2017 | 09:06 AM
mittens's Avatar
mittens
I did not tune it a long time tuner and Friend did Clyde Carlson. He is great on LS stuff but the limited amount of E92 cars under his belt so its a little new. So while I am not tuning it I am asking IF and where it can be found.
My response was not to you, but more so the guy that stated you have to be willing to loose your warrenty....... like WTF read man Cam, tuned, all kinds of other stuff going on here, and he like warrenty........
Old Dec 18, 2017 | 12:09 PM
davepl's Avatar
davepl
That's right, don't take any guff from these strangers. You demand the help you deserve! Tell 'em who's boss!
I'd help you out but all I can do is proffer that it might not all be in the tune. Imagine the engine broadcasts on the CAN bus that it's at 5400rpm. The dash sees that packet. Should it turn on a shift light? Well, it knows the temp from broadcasts too, but how cold is too cold?
WHAT DEFINES WHEN THE SHIFT LIGHT SHOULD COME ON?
Is that up to the dash? Unless there are proprietary PIDs out there for the ECM to communicate the shift windows, I think its up to the dash, not the tune.
Old Dec 18, 2017 | 12:52 PM
mittens's Avatar
mittens
I was not trying to be a jerk, but when some posts a response and its so far away form the point of the thread it is like WTF haha.
Back on topic, that's also part of the question IS it changeable, do others with a lower temp state have this issue or is it fixed somehow. If its in the BCM or something that just reads the temp form the ECU, then it make not be fixable. or like you said maybe the dash just reads that PID and does what its told...
Just would like a answer. and one guy above saying at 165 his is normal... so that seems its a fixable issue, just not sure how or where.
Old Dec 18, 2017 | 06:35 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Roger roger. In that case if I get a chance tonight I'll see if I can peek through the tables and find it..
Old Dec 26, 2017 | 09:15 AM
mittens's Avatar
mittens
Same problem, and we checked every where we could in HP tuners...
Mechanical thermostat is set to 160
The desired coolant temp table to 160
The fuel cut off start up modifier is also adjusted down to the proper intake temps as well.. but same result (even tried the whole table at 6800 once just for good measure)
Is this nor possible to fix in the tune, if not will swap back to the stock one.
Old Dec 26, 2017 | 12:58 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I couldn't seem to find it in the tune when I looked a couple days ago. I could have sworn it was in there though.
To Tach and shift light wrong with new thermostat?
Old Dec 26, 2017 | 01:13 PM
mittens's Avatar
mittens
so what Therm are you running and it doe snot do this? It seems watching a scanner. if the car hits 175... it thinks thats fully warm tach and Shift lights wise... its below that when this issues shows its face.
Old Dec 26, 2017 | 01:25 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I run a 160 stat myself. I'll have to pay attention next time I take it out and see where the temp is when the bar goes away.
Old Dec 28, 2017 | 02:54 PM
mittens's Avatar
mittens
anyone have an update?
