Wider Front Tire Only?
Old Dec 18, 2017 | 11:03 PM
oxL1GHTN1NGxo's Avatar
oxL1GHTN1NGxo
Default Wider Front Tire Only?
So I sold my C6 Grand Sport and recently picked up a C7 Stingray, which I absolutely love (although I'm still trying to get over the look of not having 345's in the rear). The car came with basically a brand new set of Mickey Thompson's in the stock 245/285 sizes which I planned on keeping, but here's my dilemma.
The wheels I'd like to buy for the car are 18x9.5 and 19x10, and I'm thinking a 245 on a 9.5'' wheel will look too "stretched". Does anyone know if I can do a 255/40 or 265/35 front tire while keeping the 285/35 rear and still have the Traction Control system be happy? If I remember correctly the C7's like to have a 1.2 diameter difference but how far (higher or lower) can you actually stray from that before you have issues? I've read through a lot threads on this but haven't found one where someone kept the stock rear tire size.
Old Dec 19, 2017 | 04:42 PM
village idiot's Avatar
village idiot
you need to keep the ratio of the tire heights between the front and rear similar. It doesn't care about width.
Old Dec 19, 2017 | 05:33 PM
MitchAlsup's Avatar
MitchAlsup
Ideal
Spec Diameter Width
235/40ZR18 21.7008 8.8563
245/40ZR18 21.8583 9.2500
265/35ZR18 21.6516 10.0374
275/35ZR18 21.7894 10.4311
285/35ZR18 21.9272 10.8248
275/35ZR18 is a slightly better fit in diameter than 285/35ZR18
However, you want to keep the width ratios similar to avoid inducing oversteer or understeer. In order to match the 275/35ZR18 you will want::
x = originalrear/originalfront*newfront
x = 285/245*275
x = 319
Old Dec 19, 2017 | 06:19 PM
village idiot
The car already understeers a bit. You can go wider in the front and not turn it into an old school 911.
I went 315/335 and its almost perfect. When I start to lose it, it went into a 4 wheel slide.
Old Dec 20, 2017 | 04:20 PM
Johnson Tang's Avatar
Johnson Tang
I have wider front tires, got 255 front and stock 285 rear, now the car doesn't under steer but over steer, so I give a little more camber and toe on the rear. Everything suits my driving style now.
Old Dec 20, 2017 | 04:43 PM
Takoyaki's Avatar
Takoyaki
Does the car not calibrate if you have different ratio? I'm looking into different autox tires now. When I had C6 Z51, right after I mounted the different tires, the car auto calibrated. Is this not the case for C7?
Old Dec 20, 2017 | 05:15 PM
village idiot
Your C6 didn't auto calibrate for new tire sizes.
Old Dec 21, 2017 | 01:18 AM
dencos's Avatar
dencos
What size rim are you using for the 315 in the front?
Old Dec 21, 2017 | 09:53 AM
village idiot
11 x18 inch (track setup)
On either my first or second session and I got a turn mixed up. I thought it was a longer turn and suddenly switched back left. You can see the car just does a perfect 4 wheel drift. I was seriously surprised- I expected a spin for sure. 315F 335R was perfect- any time I got loose, it was all 4 tires. I'll try to find the video again
On a narrow body car, I'd probably try to run a about the same type setup, almost square but slightly wider in the rear. A stock LT1 really doesn't really even 335 rear when it's an R-compound. It can put all the power down.
edit: correct video
Old Dec 21, 2017 | 12:06 PM
BrunoTheMellow's Avatar
BrunoTheMellow
edit: correct video
https://youtu.be/ymvN3d5Dj04
275-295 probably for z51. Although it really depends on your alignment and suspension setup. I've had a perfectly balanced 4 wheel slide car , a pushing car, and an oversteering car with the exact same tires 245/285 , just different suspension stiffness settings, tire pressure and alignment settings. I must say that having 1° more negative camber up definitely made the car oversteer but now it never pushes which is surprising for such narrow front tires.
but you already knew about that hahah.
Old Dec 21, 2017 | 12:13 PM
BrunoTheMellow
I an currently running a 1" taller tire in the rear and stock height tires in the front. The car didn't do anything different so they are pretty lenient. Have been for over a year with plenty of track days. Although I must warn you, rubbing sucks, taller ratios suck (z51 already struggles due to the big gap from 3rd to 4th). Everything in PTM works.
Old Dec 21, 2017 | 02:22 PM
village idiot
Yeah, you can definitely dial in/out some traction with alignment. I ran DSC recommended street setup. I think 1.2 degrees of camber.
Old Dec 22, 2017 | 01:32 PM
rb185afm's Avatar
rb185afm
I have similar results to Village. Exiting the sweeper at Buttonwillow on the stock tires, was causing massive understeer. I’m now on 315/345 and I do nice planted 4 wheel drifts. But, I have also gone .05 toe out front and rear with maxed camber. I’m at -2.8 front and -1.8 Rear. It seems like GM build in understeer for safety using a smaller front tire. I prefer the car oversteering with controllable characteristics.
Old Dec 22, 2017 | 01:37 PM
Takoyaki's Avatar
Takoyaki
Are you rubbing anywhere with those fat tires? Would you mind sharing the detail of your tire/wheel set up? I'm trying to collect more info to pick my next autox set up.
Old Dec 22, 2017 | 02:32 PM
village idiot
I'm pretty sure he has a wide body (grand sport if I recall correctly from another thread).
I'm running 315/30/18 in the front on 18x11 wheels. I'm sure if you PM the guys who do the signature wheels on this forum, they can give you the offsets they use. I didn't notice any rubbing at all.
We don't have many options for running a track tire that wide though
Hoosier R7/A7 (about $1600/set)
Ecsta V720 ACR - if you get 19's all around (315F, 355 R) ($1300)
Cup2 tires in a bunch of sizes ($1900)
R888R in a few different sizes ($1100-1300)
Those goodyears on the ZL1 1LE (305/325)
And some pirellis. That's about it.
Old Dec 22, 2017 | 03:12 PM
rb185afm's Avatar
rb185afm
Amazingly I’m not rubbing. I had some issues with traction control and slicks, but no issues with traction control turned completely off. I mistakenly though “RACE” mode was all off. It is not. I was having TC kick in durning triple digit corners on slicks, as the car though I had reached an impossible G threshold. Otherwise, zero rubbing. I’m running CCW TS12 18”X11” fronts with 18”X13”’rears. Running Hoosier R7 315/345 combos. Cool part is the slicks are only a few tenths off the stock front to rear ratio. I’m going to try A7’s next. I absolutely love this set up! Full steering lock barley touches and has not left a mark yet. During TC engaugment, my tire would barely touch the inside fender liner and fender lip while under full compression and having the brake activated, moving the rear tire back on forth under load. Even that, did not burn through the liner!
Edit: I have a Grandsport with widebody. I think some guys on this forum have fit some pretty wide rubber under the Z51. Can’t remember the details though.
Old Dec 23, 2017 | 11:46 AM
Takoyaki's Avatar
Takoyaki
Hope I'm not going off topic. The stock front to rear tire height ratio is the rear tires being slightly taller than the front. I have Z07. Is this the ratio I need to keep in order not to confuse the traction control?
Good to know you guys are not rubbing with 315/345.
I'm running in a street tire class so it limits my selection even more.
Old Dec 23, 2017 | 01:55 PM
BrunoTheMellow
yes but ive strayed quite a bit with no problem.
To Wider Front Tire Only?
