Best adjustable sway bar end links
Old Jan 2, 2018 | 12:11 AM
village idiot's Avatar
village idiot
Default Best adjustable sway bar end links
I got some adjustable sway bars off the forum but the end looks don't look so good. I figure I'll just replace them now. Who makes a good set?
Old Jan 2, 2018 | 08:52 AM
robert miller's Avatar
robert miller
I have the LG stuff on my car love them. Robert
Old Jan 2, 2018 | 09:47 AM
ErnieN85's Avatar
ErnieN85
best stuff out there
Old Jan 2, 2018 | 01:43 PM
AKKutz's Avatar
AKKutz
I have LG with LG bars, they are Heim joints. You can source these at McMaster Carr.
Old Jan 2, 2018 | 08:49 PM
robert miller
I have the z51 stuff but chg out to the LG bars & end links also a much better car now. Sold my old stuff to a guy that didn't have the z51 set up. Well worth the chg out... Robert
Old Jan 8, 2018 | 04:41 PM
Fast6.3's Avatar
Fast6.3
LG is nice they are noisey tho
Old Jan 8, 2018 | 05:32 PM
ErnieN85's Avatar
ErnieN85
only if they are worn out
Old Jan 8, 2018 | 07:14 PM
copjsd's Avatar
copjsd
The best links I'm aware of are manufactured by Anze Suspension (see:https://www.anzesuspension.com). I'm not able to recite the technical superiority of their construction, however if you call and ask for Angelo he'll enlighten you. Simply said, they are made of the best and hardest materials to the tightest tolerances, and are pre-lubricated and fully sealed for years of trouble free QUIET service.
I had them on a Porsche Cayman that had beefed up suspension/bars. The Anze links were the only ones that would stay quiet so I could enjoy a noise, vibration and harshness free ride for the street miles to and from the track events as well as daily driving.
Old Apr 26, 2019 | 03:30 PM
village idiot
Do you know the sizes/measurements? Would be kinda cool to just "make" my own for $20 rather than pay $300.
Old Apr 26, 2019 | 03:44 PM
AKKutz's Avatar
AKKutz
You would have to accommodate the 12mm bolt that holds it to the bar and control arms. Also, look for the teflon inserts.
Old Apr 29, 2019 | 04:50 PM
thrilled's Avatar
thrilled
There are other questions on sway bars.Ine guy says there is an adjustable shock that does better than the sway bars.I forget the name.They sound really good.
Old Apr 29, 2019 | 05:07 PM
village idiot
Huh? Shocks vs Sway Bars?
Our shocks (Mag Ride)are about as adjustable as it gets.
Old May 1, 2019 | 06:42 AM
k24556's Avatar
k24556
Default EndLinks
Here is a source of the Heim ends and some other parts that put the adjusting nut of a Grannatelli end link in the center of the bar (See pdf sheets). These guys sell to the dirt-track racing crowd, so their stuff is tough.
I used one of the double adjusters, one 5 1/2 inch swaged tube and one 5 inch swaged tube per side of the car. This replaces the solid tube of the Granatelli. Then the toe adjustment is no longer inside the barrel of the wheel at the Heim joint, but the center of the bar and easy to get to. Anybody that has used the aftermarket toe links knows what a PITA adjusting still is with just one long tube. Toe adjustments are now easy and much faster. On the double adjusters, the gold jam nut is LH thread
File Type: pdf
File Type: pdf
File Type: pdf
To Best adjustable sway bar end links
