E-85 require fuel pump and injector change????
Old Jan 3, 2018 | 09:08 PM
TuckerO's Avatar
TuckerO
Default E-85 require fuel pump and injector change????
Looking at some upgrades and my tuner said I may need to do more for E-85. What have others experienced on Z06? Thanks
Old Jan 4, 2018 | 10:55 AM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
Is your car NA or FI?
Old Jan 4, 2018 | 05:59 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
He mentioned Z06 so FI. Still will depend on his mods and boost level though.
Old Jan 4, 2018 | 06:38 PM
TuckerO's Avatar
TuckerO
Plan to do a Pully swap, halltech cai and Akrapovic cat back exhaust. Not much after that. See a lot on here about e85. My tuner said he would have to check and see if the stock set up would support the extra fuel. Just thought i could find out quicker on the forum as several on here already know the answer I am sure. Thanks
Old Jan 4, 2018 | 07:27 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
You should be able to run close to full E85 with that setup. Your fuel system should handle it..
Old Jan 4, 2018 | 08:34 PM
robert miller's Avatar
robert miller
Man if I were you I would look at a new tuner someone that has done more than a few tunes on the c7. On your set up that you are saying here on this DI inj's like Ant has said you should be 100% good on no more than you have done with the car.
Now the LS stock inj on the c5 & c6 diff story all together. I am not saying you have a bad tuner just if he has done what you are saying he should be able to tell you right off about 100% you will be good to go. Robert
Old Jan 4, 2018 | 10:02 PM
TuckerO's Avatar
TuckerO
Yes I was a little concerned about the lack of knowledge on the Z06. He does a lot of camaro’s. I am in central Arkansas and there is not a lot of C7 Z06s being modded in this low populated area. I have a lot of respect for this guy as he has done other things for me in the past. I also do like that he says what he knows and what he does not know. I am confident on having him do the Pully and tune. He seems to be real high on doing meth injection. I do appreciate all the help and any additional advice from you guys. I just do not want to go overboard with this car. Opinions on meth greatly appreciated also. Thanks
Old Jan 4, 2018 | 10:24 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
You can never go wrong with meth. Adding meth will allow for additional octane and supplemental fueling if necessary.
To E-85 require fuel pump and injector change????
