Electronic Torque Wrench Recommendations
Any recommendations? Quality? Price/Value?
Thanks!
There was a vendor selling a cheapo one here a while back. I got it and it was a total waste of $. By the time I would move from one wheel to the next, the frigging thing would turn itself off and it was a real PITA as you have to reset your torque setting each time! JUNK!!!
I tossed it and got a click type. Not much made in the US anymore. The click type works great even though it came from China.
http://www.sears.com/craftsman-1-2-i...4&blockType=G4
You have small thing that require in-lbs, and things that require small #'s of ft-lb, and some things that require lots of ft-lbs. That's 3 different wrenches.
How precise do you want to be vs need to be?
Unless you are rebuilding engines, you probably don't requrie a wrench that also measures torque angles, You probably don't need a 250 ft-lb scale.
Ideally, you want to use a wrench where the applied torque value is between 1/4 and 3/4 of full scale. That is where most wrenches are most accurate.
Ok, that said, most people would be completely ok using a Harbor Freight Tools 1/4" or 3/8" Drive 0-25 ft-lb and a 1/2" drive 0-150 ft-lb Those two should cover just about anything, and they have been tested as being accurate enough +-3% over the useful range.
Yes, you can buy a really expensive torque wrench, and have it calibrated, be all happy with +-2%.. but in the real world.. it doesn't matter.
Yes, I've got a couple of HFT torque wrenches, (I've also got a Snap-On, a wrench that measures torque angles, and an electrontic torque application meter)
Guess which ones I grab for working on cars? (most stuff, but not rebuilding engines...) The HFT wrenches.
If you are feeling really ****, you can set the wrench to some number in the operating range, clamp the wrench in a bench vise, and hang weights on the wrench to test it. Yes, it might require some math, but you could build your own calibration table for the wrench... Well it gives you something to do on cold winter days.
(just be glad you don't have to torque steam turbine casing bolts on a submarine. induction heaters to heat the bolts, micrometers to meaure bolt stretch, 1000 ft-lb torque multipliers...)
http://www.brownlinemetalworks.com/torque-wrench
Feels well made. Operationally it works well, with the caveat that you need to be aware how the peak hold feature works.
It does go through batteries faster than expected - seems like they drain very slowly when in storage. A bit annoying, but not a deal breaker.
Bill
Bill
I ended up fixing my Craftsman by buying the a new ratchet/gear and then I found a local one man shop that calibrates all types of tools for local businesses.
I was able to watch him test my torque wrenches (I brought 3 with me). It was interesting to watch him and he showed me how he could manipulate the readings. For example, your hand must only be in the grip part. If you move it up or down the bar, even slightly, the readings change. Pull real fast, yep different readings.
What I learned is you need to only touch the bar with one hand on the grip and pull slow and steady.
and remember to take out the batterys in your electronic wrench,i just tried my $400+ snapon 3/8'' and the batterys fryed,and snapon says its more to fix it then it worth
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://smile.amazon.com/ACDelco-ARM...+wrench+torque
For doing wheels, though, I use torque sticks and an impact:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
The first 4-5 times I used them I went around with the torque wrench after, and they were always within 2-3 lb ft. So now I trust them and only check one nut on each wheel afterwards :-0
I am glad I didn't buy that one almost done it. But ended up also with a good snap on set up..
