Heat Exchangers
Old Jan 24, 2018 | 05:23 PM
LAYNLOW's Avatar
LAYNLOW
Default Heat Exchangers
Anyone have any experience with aftermarket heat exchangers? If so, which one did you go with and why.
Thanks!
Old Jan 24, 2018 | 07:06 PM
AZGASSER's Avatar
AZGASSER
When I upgraded my upper and lower pulleys I did the upgraded HX from Cordes (CPR) in Phoenix. I also did the Fasterproms expansion tank at the same time. Larger HX core and more fluid volume makes the IAT increase more slowly. I really did not research HX that much as I knew Joe and his products are top notch and he would not steer me wrong.
Old Jan 24, 2018 | 07:14 PM
LAYNLOW's Avatar
LAYNLOW
I have also heard great things about Cordes/CPR. I do have an expansion tank as well. Thanks!
Old Jan 24, 2018 | 07:52 PM
Cordes Performance Racing's Avatar
Supporting Vendor
I really did my homework on our core when we decided to do a HX. Our unit doesn't require anything to be cut and connects to the oem lines. Our tank as well uses oem quick connections and has a mount for a mighty mouse catch can, AZgasser's car we did a fasterproms because at the time ours was not made. We have these in stock and can ship them out asap.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Jan 25, 2018 | 06:44 AM
LAYNLOW's Avatar
LAYNLOW
Thank you!
To Heat Exchangers
