AFM Delete
Old Feb 2, 2018 | 04:35 PM
kentross1's Avatar
kentross1
2nd Gear
Default AFM Delete
Best mod to delete AFM modules in 2017 GS corvette auto?
Old Feb 2, 2018 | 06:46 PM
C5_Tom's Avatar
C5_Tom
If you want to keep your warranty intact using a Range AFM Disabler might be your only option. Otherwise you can have it software tuned out or the engine modified to remove the DOD components. The software option will most likely put you in peril for a warranty block if a dealer checks the software. Rebuilding the engine will definitely void your warranty.
Many of us here use the range module, it just plugs into the OBDII port. If you drive in manual mode all the time the AFM does not activate.
Old Feb 2, 2018 | 10:24 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Are you looking to removd the modules/actuators from the exhaust?
Old Feb 2, 2018 | 10:36 PM
Chets LS3's Avatar
Chets LS3
delete them or disable them? theres options for both
Old Feb 3, 2018 | 01:35 AM
irun4cops's Avatar
irun4cops
I'm curious how to keep them closed more often
To AFM Delete
