'17 GS bolt-on's/ported OEM heads new PB
Went to the track today and managed a new best with the current setup. DA for the 10.74 run was -250ft but ran multiple 10.7s in da between -250ft and +380ft as the day warmed up
Mods are:
Pray Performance oem ported heads
Pray Performance oem ported intake manifold
Pray Performance oem ported throttle body
Pray Performance flex fuel tune w/ E85(76% today)
Halltech CAI
ARH 2" headers w/ 3" catted xpipe into oem NPP
Forgestar drag pack(18x5/18x12 w/ 305/35-18 ET Street SS)
Launch pic not from today, but didn't have any current ones
Mods are:
Halltech CAI
Dam!! Definitely badass!! I had a manual challenger that I just couldn't get into the 11's. I now have a manual z51 that I wanna take to track but don't wanna go till I know I'll be under 12? All I have done is haltech. Think I'd be there if did the headers and a tune also?
Thanks and good luck!
Thanks!
The biggest issue with the manual will be getting the launch down. The autos are for sure easier to launch. You should be able to get in the 11s easily with a good 60ft. Headers and flex fuel tune will add quite a bit to the car. I would want the headers for the sound alone... they scream at full tilt
Thanks!
I'd look into a drag radial.
Maybe will they fit on a 18x12 wheel though?
Thanks!
You mean trans/rear/axles? Yes. Stock A8 with stock converter. Motor is stock other than the ported oem items on top end.
ALso did go 10.85 before the ported heads w/ boltons only. The ported heads throw me into the head/cam group now.. so I am a little on the slow side compared to others right now.
Thanks!
Dig
Thanks!
Thanks!
Next mod converter ?
Yeah, probably wont change up rear wheel setup for minimal gains. Now if I was 1 tenth away from the record.. then for sure.. would give it a go. I am in NC, but I appreciate the offer
Probably not too far for you.
If you wind up going, I'll find a way to get you them.
Thanks!
