Cutout question
Old Apr 17, 2018 | 01:44 PM
DomLS3's Avatar
DomLS3
Default Cutout question
Would it be possible to wire electric cutouts to open and close with the stock NPP valves from the infotainment system? For instance, if I selected "track" under engine sound management, it would open the electric cutouts and NPP cutouts but anything else selected would just open NPP cutouts and not electric ones? Trying to figure out a universal way to do it without having to install a switch.
Old Apr 17, 2018 | 07:44 PM
rrsperry's Avatar
rrsperry
It should be. Doing it might be a much harder proposition.
Old Apr 17, 2018 | 11:08 PM
JHEBERT's Avatar
JHEBERT
NPP is on fuse 42 I THINK...when the fuse is pulled the valves are open. You can start with that circuit but will still need some type of module to control the cutouts. You can’t just continuously send power to the cut out, it will not live. You could probably incorporate one of the “one button touch” kits to work as you describe.
To Cutout question
