I just recharged the battery that was flat dead and got her running after a long winter. After manually popping the door open and firing it up I noticed the drivers window won’t go down or index. I’ve checked the 30amp fuse and even switched the fuse with the other 30amp fuse - no luck. I also did the indexing procedure and disconnected / reconnected the battery. Does anybody have any words of wisdom? I have a 2014 z51 Vert.
I've read a number of posts on here of folks seeing weird symptoms in cars that had dead/weak batteries. I'd either keep it on the charger till it's full or drive it around to put a good charge on it. After that, try everything out and see if things are working.
