Elite E2 Catch Can
Old Apr 23, 2018 | 06:04 PM
Chazzmania's Avatar
Chazzmania
Default Elite E2 Catch Can
Hey guys so I searched the forum to try and possible locate some pics of this catch can installed on a Z51 car. Basically I have all the lines hooked up except for the one that needs to be installed into the intake assembly. I am trying to verify if this is really necessary. I have an aftermarket intake manifold and I really don't want to drill a hole into the intake tube. If any could chime in or drop some pics of their install or recommendations I would greatly appreciate it.
Old Apr 24, 2018 | 12:25 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
FWIW, I installed one on my Z51 and removed it when I sold it and it's on my Grand Sport.
This is a PDF with many pics AND my reason for not using both exits and NOT drilling a hole in the air intake tube! You'll find interesting: http://netwelding.com/Catch_Can.pdf
Just use a plug on the left hole!
Old Apr 24, 2018 | 01:00 PM
Chazzmania's Avatar
Chazzmania
The forum never disappoints thanks for the info. So basically you used the top and right side ports. That's how I have it setup now, just wanted to verify if anyone else completed the install. Also what did you use to plug the hole. Also with the clean oil separator you didn't cut the factory line and use a T connector like Elites directions stated? Looks like you ran your hose from the CAI port back to the Clean Oil Separator port.
Old Apr 24, 2018 | 01:41 PM
JerryU's Avatar
JerryU
Don't recall the size plug. Had a number I used on my street rod. It's a pipe thread. Looks like a trip to Ace hardware!
My 2014 Z51 had two barbs on the air intake tube. If you have only one than a splice would be needed.
Of interest, the Grand Sport only has one line and my aFe intake had two barbs. aFe sent me a plug! It is an odd size the Elite is not- I'd guess it is a 3/8 pipe plug.
PS: decide not to bother with the "Clean Side Separator" on the Grand Sport since it has lines going to the valve covers.
Old Apr 24, 2018 | 01:45 PM
Chazzmania's Avatar
Chazzmania
Thanks for the help
Old Apr 24, 2018 | 04:04 PM
Clifftrail's Avatar
Clifftrail
I have the E2 and installed per Elite instructions. No issues with mine, I have OEM tube and did drill hole.
Old Jun 22, 2018 | 03:45 PM
blue max's Avatar
blue max
Do you know if the Z-51 has the lines going to the valve covers also
Old Jun 22, 2018 | 04:50 PM
JerryU's Avatar
JerryU
Assume all newer Dry Sumps have the same configuration. I'm collecting ~1/2 what I used to in my 2014 so GM has made and improvement.
Old Feb 6, 2019 | 10:28 AM
c4t's Avatar
c4t
reading this post made me more confused than before, now I dont know if I should do the catch can or not
Old Feb 6, 2019 | 12:08 PM
JerryU's Avatar
JerryU
If you are referring to my old post that said with my Grand Sport with it's ungraded an more complex PCV systemI was capturing ~half the ~1oz/1000 miles I did with my 2014 Z51, now after two years it averages 80%. So the new PCV system helps but not that much.
If you keeping the car over ~50,000 miles it may be worth it for even the “mostly cosmetic” reasons Tadge says the coking will affect. It no doubt is a bit more of an issue than cosmetic, but if you seldom get near redline you will probably never notice any difference even with -50,000 miles.
There is the warranty issue risk.
Just my opinion.
Old Feb 6, 2019 | 02:30 PM
Rayland's Avatar
Rayland
Banned Scam/Spammer
Chazzmania;
No! Mr. Tadge Juechter discusses this topic and he suggested it was not necessary for the dry sump configuration, since it was already addressed, in the oil return lines?.
Please note: he also did not think it was necessary for the wet-sump stingray either?
Conversely, the 2016 Camaro SS wet-sump got one?
Yes, I have installed an Elite catch can for my wet-sump stingray. "DI=direct injection". Requirement?
Many thanks,
Ray
Old Feb 7, 2019 | 09:17 AM
subieworx's Avatar
subieworx
You definitely want all of the ports hooked up!
Elite on the z51 is using the two outer ports as return ports and the center port as the feed to the can from the valley cover. You want one of the side ports going to the intake manifold and one of the side ports going to the intake before the throttle body. This will ensure that you are always drawing a vacuum on the crankcase both in cruise conditions and at WOT. If you don't hook the return port up to the intake you will not be pulling much of a vacuum at all on the valley cover breather at WOT as the intake manifold will reach near atmospheric pressure.
Old Feb 7, 2019 | 02:08 PM
JerryU's Avatar
JerryU
If Tracking that might be useful. However I don't Track and my WOT time, although at times frequent, are short duration. I did not bother drilling a hole in the air tube before the Throttle Body. Was easily reversed when I sold the car and I installed my Elite Can in on my Grand Sport the same way. I just plugged the second exit on the "Can."
To Elite E2 Catch Can
