PID FOR E85 Content on C7Z06!
Old Apr 26, 2018 | 10:23 PM
Rdubfalco's Avatar
Rdubfalco
Default PID FOR E85 Content on C7Z06!
Hi Guys,
I'm currently running the Torque Pro App via a Bluetooth OBDII Scanner. My mods are kooks LT's catless X, AFE CAI, NGK plugs and E55. I was wondering if anyone knows the PID for the monitoring Ethanol Content as my tune is for E55. Any help would be appreciated. Thanks.
Old Apr 26, 2018 | 10:58 PM
bigsapper's Avatar
bigsapper
Mode & PID: 220052
Equation: (A/255)*100
Old Apr 26, 2018 | 11:08 PM
Rdubfalco's Avatar
Rdubfalco
Originally Posted by bigsapper
Mode & PID: 220052
Tried this with engine running and it did not work, saved it, but how would I know it's activated? Should I try with engine off??
Old Apr 26, 2018 | 11:55 PM
Rdubfalco's Avatar
Rdubfalco
Anyone else have any ideas/input? Would be much appreciated.
Old Apr 27, 2018 | 07:28 AM
bigsapper's Avatar
bigsapper
You have a sensor installed, right?
The above works for me. I got that off a CTS-V forum.
http://www.ctsvowners.com/forum/62-g...ml#post1219425
Old Apr 27, 2018 | 01:33 PM
Rdubfalco's Avatar
Rdubfalco
Correct I have the sensor installed and activated as my tune is calibrated at E55 (Max) on stock fuel system for the C7Z06. I have the PID code in there, but I'm trying two figure out how to enable it? Thanks again!
Old Apr 29, 2018 | 03:10 PM
bigsapper's Avatar
bigsapper
Do you have HP Tuners or EFILive? If so, can you read it using that?
Old Jan 2, 2019 | 08:39 PM
ptevo03's Avatar
ptevo03
Anyone figure out the correct pid? I used the same custom pid above and it says at idle I'm running 158%?
Old Jan 2, 2019 | 10:56 PM
Matthewstorm's Avatar
Matthewstorm
I tried the aforementioned PID formula with Torque Pro on my Flex Fuel sensor and it just wouldn't work. The scanner my performance shop uses read the E85 fine but tried for 2 hours to get mine to work but never could. I give up.
Old Jan 3, 2019 | 07:21 AM
ptevo03's Avatar
ptevo03
I just wanted to say I messed it up the above pid did work for me I had c° under unit type for some reason, changed it to % and it works! I'm in NC and got the flex fuel from sheetz. Torque pro is reading 70%.
Old Jan 3, 2019 | 01:25 PM
C7&7's Avatar
C7&7
what year car? The alcohol content PID for my 2014 is 27 (according to what I programmed in my dashlogic)
Old Jan 3, 2019 | 02:03 PM
ptevo03's Avatar
ptevo03
I have a 2016 z06
Old Jan 3, 2019 | 04:05 PM
Matthewstorm
I have a 2015 Z51.
Old Jan 3, 2019 | 04:20 PM
Matthewstorm
Where did you get your Dashlogic? Was it difficult to program for E85? Thanks.
Old Jan 4, 2019 | 09:22 AM
C7&7's Avatar
C7&7
I bought it from Dashlogic. Or Palmer or whatever they’re called. Was super easy to program.
Old Jul 2, 2021 | 01:36 PM
ImpliedConsent's Avatar
ImpliedConsent
Mode & PID: 220052
Bringing this back as relevant for my recent installations. This is the exact PID and equation needed for Torque Pro.
Old Dec 5, 2021 | 11:04 AM
Travlee's Avatar
Travlee
I tried this and it is not working using torque lite, do I need pro? Any ideas?
Old Dec 9, 2021 | 07:30 AM
TJay74's Avatar
TJay74
This information is correct and is what I use, but I use Torque Pro. I think you have to be on the Pro version in order to make custom PID's. From there you have to add a display to your panel and select the one that is name E85, not the one that says Ethanol.
Old Dec 9, 2021 | 07:52 AM
Travlee's Avatar
Travlee
good to know, appreciate the response sir. ended up ordering the Fuel-It analyzer
To PID FOR E85 Content on C7Z06!
