Bolt Torque Value
Old May 10, 2018 | 08:06 PM
Harris's Avatar
Harris
Default Bolt Torque Value
Would anyone have the torque spec for the bolts that secure the underbody braces for a Z06? These are the braces that go from the front cradle to the body. Chevrolet sells carbon fiber replacements.
I am not replacing mine, I had one off the car to add insulation to the oil lines.
Thanks in advance. Gary
Old May 10, 2018 | 10:48 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
If you can show a picture of which bolts specifically on the car I can look it up for you
Old May 11, 2018 | 01:13 AM
snomuncher's Avatar
snomuncher
Default Torque Values
From the 2015 Service Manual, Section 3:
Front Cradle Stabilizer Bar Bracket to Frame Rail: 110 N-M or 81 ft-lb
Front Cradle Mounting Fasteners: 160 N-M or 118 ft-lb
Underbody Side Rail Cross Brace- Front: 100 N-M or 74 ft-lb*
*Note: These are the diagonal braces.
Old May 11, 2018 | 07:34 AM
Harris's Avatar
Harris
Great, thanks for the help! The diagonal brace values are the ones I was looking for.
Does the manual indicate if these are one time use only fasteners?
I need to get a manual one of these days.
Thanks again,
Gary
Old May 11, 2018 | 09:25 AM
snomuncher's Avatar
snomuncher
Default Bolt Torques
Thanks again,
Gary
There is no indication that these are torque-to-yield, single-use only bolts.
Old May 11, 2018 | 10:29 AM
Harris's Avatar
Harris
Thanks for your help, snomuncher!
Gary
To Bolt Torque Value
