Engine run-on
Old May 16, 2018 | 11:16 PM
Edinacorvette's Avatar
Edinacorvette
Default Engine run-on
Howdy, I have a 2014, m7, z51, completely stock.
I’ve noticed that when I accelerate moderately or more, when I lift off the gas, it stays at that RPM for about a half second before it reduces.
I expect this is “normal” for stock but any other ideas on how to get it to reduce RPM immediately?
(Maybe it’s the stock tune)
tia
Old May 17, 2018 | 12:01 AM
The HACK's Avatar
The HACK
Most modern engines are tuned to keep RPM up for a little while to prevent the formation of NOx.
Old May 17, 2018 | 09:01 AM
Edinacorvette
Default The Hack
thank you Sir...I had a hunch it was an algorythmn in the stock tune. I can live with that.
Cheers!
Old May 18, 2018 | 02:41 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
That and the flywheel/clutch assembly in these weighs eleven billion pounds, which makes the transition from throttle to idle and revving from idle take forever....
Old May 18, 2018 | 03:46 PM
Edinacorvette
Roger that.....ya, tons of weight. It sure aint no flat plane crank!!
How i do love the rumble though!
To Engine run-on
