416 Build (Questions)
Old May 19, 2018 | 08:33 AM
KKC7's Avatar
KKC7
Default 416 Build (Questions)
After learning that my car spun a main bearing the choice was take it to a machine shop to get cleaned up and rebuilt or buy a new short block. I went ahead and bought a new 416 stroked short block and will be dropping it in late next week pending on arrival.
I will also be installing a cam once it is speced out with shop. What else should I be thinking about since I am this far?
What is trully the most cost effective way besides cam/meth (which I will have) in gaining fuel at this point? Already have lt4 injectors and hpfp.
Never thought it would come to this when I rolled it off the lot. 😂
Old May 19, 2018 | 10:37 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Fuel is challenging. If you already have the LT4 high side stuff, and you are doing a cam with a 32% lobe then the only thing left to do is to make sure to measure and use a lash cap. This will net you even more fuel. Your nect avenue with fueling is to do a low side fuel pump system.
Old May 19, 2018 | 04:54 PM
KKC7's Avatar
KKC7
Looking into low side. Few different setups I'm noticing. Be nice if there was information on LT5 parts
Old May 19, 2018 | 05:17 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
What do you want to know about the LT5? I can tell you the DI injectors and HPFP are the same exact ones used in the LT4. I don’t have aby info on the part numbers for the PFI setup. I do have the part number for the ZR1 low side fuel pump which IS slightly higher flowing than the Z06 if you need it. Currently unknown if it is plug and play though.
Old May 19, 2018 | 06:42 PM
KKC7's Avatar
KKC7
You pretty much answered all my questions right there. Wondering about low side, but sounds like I be better going with another route especially not knowing if it will hook up and work.
Old May 19, 2018 | 07:03 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I am planning to buy the low side pump and do it and keep my fingers crossed it is plug and play lol.
Old May 19, 2018 | 07:30 PM
robert miller's Avatar
robert miller
Ant do you think it will be that easy buddy. Hope it is for you anyway let us know on it. I think I will break down & do a forged motor & small cam this coming winter. Going to start getting parts soon so let me know if it does.. Robert
Old May 19, 2018 | 07:46 PM
KKC7's Avatar
KKC7
Ant care to share part number and maybe cost?
Old May 19, 2018 | 09:10 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Easy?! Lol yeaaaaah... NO. have to drop the tank! On an A6/A8 you must drop the trans to pull the tank. On the M7, you dont have to drop the trans but its still not easy.
84240348
To 416 Build (Questions)
