Infotainment screen will not open
Old May 26, 2018 | 05:03 PM
DVD's Avatar
DVD
7th Gear
Default Infotainment screen will not open
2015 stingray
Old May 27, 2018 | 10:37 AM
Johnp94's Avatar
Johnp94
Only thing i can think of is make sure it isnt in valet mode.
Old May 27, 2018 | 11:21 AM
DVD's Avatar
DVD
7th Gear
Default Valet
I did not touch that. Could valet be set without a code.
I put my phone in there when i got home went to open And would not open. Could I have set it in error
Old May 27, 2018 | 11:50 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Phone shifted and is blocking the door from coming down.
Elmer
Old May 27, 2018 | 12:01 PM
DVD's Avatar
DVD
7th Gear
Elmer
can i fix that
Old May 27, 2018 | 12:05 PM
eboggs_jkvl
Moderator emeritus
Originally Posted by DVD
can i fix that
Well, if it shifted to the rear to block the door, you might want to drive the car slowly and hit the brakes hard a few times to see if you can force it forward to let the door open?? Just guessing on this as a procedure if the phone is blocking the door?
Elmer
Old May 27, 2018 | 12:16 PM
DVD's Avatar
DVD
7th Gear
I did try that The cover of phone has a rubber edge and I believe it is stuck
really do not want to take it to dealer
any other suggestions would be much appreciated
I believe that is the issue
Old May 27, 2018 | 12:19 PM
DVD's Avatar
DVD
7th Gear
Elmer
it tries to open but seems to be block the phone I think
Old May 27, 2018 | 12:27 PM
TNSQUIRE's Avatar
TNSQUIRE
If your phone is blocking it, see if you can thread a piece of wire into the top enough to move he phone a little. I've heard some have had success with it.
Old May 27, 2018 | 02:20 PM
George_L's Avatar
George_L
If you have an M7 make sure it isn't in reverse. Even with the car turned off, the screen won't open with the transmission in reverse.
Old May 27, 2018 | 05:58 PM
Avanti's Avatar
Avanti
With the number of threads I've seen like this it would seem there would be SOME sort of manual fail-safe/over-ride. Reminds me yet again why I ignore it exists. Best of luck with it!
Old May 28, 2018 | 10:38 AM
eboggs_jkvl
Moderator emeritus
Does it open at all? Is there any way to get a coat hangar wire in the cubby? If you are completely stumped, you might need to take the dash apart to get into the cubby. It can be done using many videos of how to take the dash apart but it's time consuming. If you get the dealer involved, it's lots of labor hours (big bucks) to get in to the cubby.
Elmer
Old May 29, 2018 | 12:58 PM
robert miller's Avatar
robert miller
Elmer
But time is all it is if you have to pull it apart look in here at DIY on the job. I have had mine apart 3 r 4 times at least now. Not bad by the post on DIY in here. Robert
Old Jun 3, 2018 | 03:12 PM
DVD's Avatar
DVD
7th Gear
I took my car to the dealership. Not sure how they got it open. But they did and did not charge me.
Thanks for all the input
Old Jun 5, 2018 | 11:57 AM
iclick's Avatar
iclick
I took my car to the dealership. Not sure how they got it open. But they did and did not charge me. Thanks for all the input
I would ask them and then report back, as it may come up again for someone else. Maybe there's a trick they know that we don't.
To Infotainment screen will not open
