Potential oil?
Old Jun 4, 2018 | 05:58 PM
raylo's Avatar
raylo
LOL... no one here is taking this all that seriously except you guys! This qualifies as a first world problem... which means it really isn't a problem. And some of us don't have the warble, don't have a fuel tank leak (yet), or have an soon to destruct A8. So alls we have to talk about is our oil changes. To me the Dexos thing isn't a big deal. I find the viscosity question more interesting. GM makes a spec based on wherever you drive the car from Alaska to Miami. Me? I don't see the need or value in putting anything 0W in my car where and how I drive in between the mid Atlantic and Florida. So I am liking the 5W-40 offerings. Maybe splitting hairs but so what?
Originally Posted by TEXHAWK0
I agree. Sometimes you just want to reach out and slap them and say "Snap out of it!"
I actually use Valvoline Synpower 5w30 in ALL my cars and none have imploded yet.
Old Jun 4, 2018 | 07:01 PM
TEXHAWK0's Avatar
TEXHAWK0
Also, having grown up in the straight 30 weight generation, I still have difficulty trusting that multi-weight oils really change viscosities when they are supposed to, especially the 0 weight! It is against my engineering intuition that viscosity can actually increase as the oil gets hot, and decrease when cold.
Old Jun 4, 2018 | 07:07 PM
raylo's Avatar
raylo
Me, too. I grew up with straight weight, then lots of 10-40. For multi-grade formulas the oil really doesn't get thicker as it gets hot. As temp rises the viscosity modifiers just cause the oil to get thinner more slowly and never get thinner than the same straight weight of the higher number (like 40 weight) would. Just the reverse on the low end. The bigger the range the more modifiers you need.
Old Jun 4, 2018 | 08:01 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
It doesn't increase in viscosity with temp it just reduces like a heavier weight oil. I recall the "original" Mobil 1 that was made from man made molecules did reduce very little. It was a Group IV oil, which since 2000 it's no longer. Either is the Valvoline made from natural gas. It like Mobil 1 is a Group III. I looked into the properties thinking if it was the old Group IV and it might help with "coking." Turns out no oil can really help baking on a 500++ degree F intake valve!
(Group IV base oils are made from polyalphaolefins (PAO), which are chemically engineered synthesized base oils. PAOs offer excellent stability, molecular uniformity and improved performance. There are some Group IV oils but very expensive. )
Our resident forum oil expert LDB, says he is also concerned about pushing it too far as over time those "viscosity improves" deteriorate. He was going to see just what they are using from their SDS sheets if possible. They may have developed a newer product that retains it's properties for a year or so!
Recall asking Dale Inman, when we worked with the Petty Racing Team years ago, about the 00 (or some such name) oil they were using to get extra hp/mpg! Wondered what it did for wear! He just laughed and said works great for the 500 miles we need!
Old Jun 4, 2018 | 08:09 PM
Patman's Avatar
Patman
Trust me, oil does not get thicker as it gets hotter, it gets thinner. If you look at the specs on this oil you can see that, because at 40c the oil has a viscosity of 69 cst and by the time it warms up to 100c that viscosity is now thinner, at 12.9 cst.
Old Jun 5, 2018 | 09:13 AM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by rrsperry
Oh dear god... Just stop it...
You all going on and on about this is like people asking if buying a lottery ticket at a Jiffy Mart gave them a better chance of winning that one bought at a circle K...
The chance of ANYONE having an oil related failure due to not using Dexos cert oil is about ZERO. Just like your chance of winning the Mega Millions.
Old Jun 6, 2018 | 02:36 PM
TEXHAWK0's Avatar
TEXHAWK0
I thought the whole point of multi-weight oil was to act like 40 weight when up to temperature, but be 0 weight when starting a cold engine.(less protection, but will flow faster)
Old Jun 6, 2018 | 03:12 PM
Patman's Avatar
Patman
It's not quite that way. An oil that has the 0w rating simply flows a lot better in the extreme cold than an oil with the 5w rating. In order to get the 0w rating it needs to pass a more stringent cold cranking test (at -30 or -35 degrees for instance) than an oil with the 5w rating. But all motor oil is going to still be thicker when the temperature is cold and will then thin out when it gets hot. Viscosity Index improvers keep it from thinning out too much in extreme heat, which is one of the ways that this new oil can get the 0w40 designation, as it can remain a 40 weight oil at 212F.
