C7 main cat delete kit
The OEM manifolds flow well on the z06 but the kinks in the system are the main cat pipes and also the mid pipe.
In stock ready to ship
$739 shipped to the lower 48 states
3" stainless steel
FULL 304 STAINLESS WILL NOT RUST LIKE OTHER CAT DELETE KITS OUT THERE!!
Bolt in deal
Replaces oem pipes from manifold exit to midpipe entry
Pipes are farther away from oil cooler/lines to keep temps lower
Ceramic coating is optional
I can set you up with a paypal bill or you can shoot me a paypal payment tony@c7z06owners.com
I can also offer a bolra mid pipe to make it a bolt in deal which is $450 shipped.
Oh and be prepared to have a race car sound in track mode. It will be loud but due to keeping stock mufflers with valves closed will be perfectly fine and mild.
Note IF YOUR NOT TUNING YOUR CAR YOU WILL NEED 2 BIG DADDIES GARAGE 90 DEGREE 02 SIMULSTORS FOR BOTH 02 SENSORS THAT ARE AFTER THE MAIN CATS. THIS WILL PREVENT A CHECK ENGINE LIGHT
INSTALL (I highly recommend getting the borla x pipe at same time which I can set up)
1.Disconnect battery
2.Remove tunnel brace
3.remove X-pipe
4. Unbolt engine mounts from cradle
5. Support engine
6. Lift engine
7. Unbolt cradle (6bolts)
8. Remove bolts from flange
9. Install off-road pipes
If you dint want to lift engine you can remove the studs that are on manifolds and replace with these
https://m.ebay.com/itm/10-M10-1-5-x-...&ul_noapp=true
3" stainless steel
Bolt in deal
3.remove X-pipe
5. Support engine
6. Lift engine
For the cars and coffee once a week then park it crowd, black soot isn't much of an issue. Whether or not there are catalytic converters under there
