2017 GS with LT4 Blower
Old Jun 16, 2018 | 09:08 PM
1985airborne's Avatar
1985airborne
Default 2017 GS with LT4 Blower
Yes its another one...Thanks Cajon @ edgyvette! and Crawford Racing!
I'm a do it yourselfer; everything was pretty straight forward for the most part.
Old Jun 16, 2018 | 10:15 PM
onebad1lE's Avatar
onebad1lE
Sweet. Who tuned it ? Stock pulleys ? And alky .?
Old Jun 17, 2018 | 12:13 AM
1985airborne
Crawford racing...stock pulleys and yes alky.
Old Jun 17, 2018 | 01:43 PM
Crawford-Racing.com's Avatar
0Crawford-Racing.com
Former Vendor
Looks right at home in there!! Good job!
Old Jun 19, 2018 | 01:58 PM
Bruce_K's Avatar
Bruce_K
Numbers?
Old Jun 24, 2018 | 05:46 AM
1985airborne
Originally Posted by Bruce_K
Numbers?
Not sure but i made 10 lbs of boost and she hauls ***!
Old Jun 24, 2018 | 05:24 PM
onebad1lE's Avatar
onebad1lE
Sweet ride. Congrats
Old Jun 24, 2018 | 07:05 PM
Maxpowers's Avatar
Maxpowers
Nicely done. A sleeper!
Old Jun 25, 2018 | 01:51 AM
Poppacapp's Avatar
Poppacapp
Sweet setup! I do have a question though. With the GS being a dry sump motor, why does your drivers side valve cover have the oil fill lid? Do the dry sump motors have that?(Maybe I have missed it)... I thought we fill through the dry sump tank.
Old Jun 25, 2018 | 09:58 AM
Checkmate1's Avatar
Checkmate1
Not sure if you realize that the LT1's bottom end is not built to handle that level of boost.
Explains why the LT4 motor has Forged Pistons, Titanium Intake valves etc.
Old Jun 25, 2018 | 12:06 PM
Poppacapp's Avatar
Poppacapp
It can handle around 650-700rwhp. Weak point being the pistons. Cunningham Motorsports has a simple drop in poston-rod replacement set that you can swap in and handle over 1000rwhp.
Also an LT1 will make more power at the same boost level than the LT4.
with that being said, I personally would rather start with the forged LT4 from the get go.
Old Jun 25, 2018 | 04:45 PM
bc928's Avatar
bc928
Is there a crank difference between the Lt1 and Lt4?
Old Jun 26, 2018 | 07:47 AM
Zap City's Avatar
Zap City
St. Jude Donor '13
Any hood clearance issues?
Old Jun 26, 2018 | 06:56 PM
1985airborne
Numbers?
Havent dyno'd yet. But my fuel system is upgrade to LT4 injectors and HFFP. You wont be disappointed!
Old Jun 26, 2018 | 07:36 PM
1985airborne
Thanks! Exactly!
Old Jun 26, 2018 | 07:39 PM
1985airborne
Good question: I have no Idea. That's how it was.. But my motor is dry sump and I fill it through the dry sump.
Old Jun 26, 2018 | 07:42 PM
1985airborne
I upgrade to a Z06 hood. But the stock hood requires you to take the insulation out if you are running a 2017 lid. 2015 lid which is flat you shouldn't have a issue.
To 2017 GS with LT4 Blower
Old Jun 26, 2018 | 08:02 PM
MCK_Z06's Avatar
MCK_Z06
Because they all use the same valve covers. On the dry sump cars the cap is just to cover the hole.
It cannot be removed without removing the clip installed on the back. It will only moves like 1/2 a turn but doesn't get loose.
Old Jun 26, 2018 | 08:25 PM
1985airborne
Are you referring to part numbers or material?
Old Jun 26, 2018 | 08:35 PM
1985airborne
I'm building a forged motor here shortly...I'm familiar with each motors capabilities...But when your tune is spot on my worries are minimum.
