Optimal Stereo Upgrade?
I have been formulating a plan for a optimal upgrade for the 2017 Convertible Corvette stereo system keeping all stock system controls and head unit and will be easily reversible back to stock.
The base source will be iPhone X connected with USB cable playing Flac music tracks with a Flac player app.
Nav-TV M650-GM interface utilizing optical out at 24/96 to a JL Audio VX1000/5.i amp.
Replace door subs with JL audio C7-650cw Component Woofer fed by JL amp, leaving the mids, tweets and center channel intact to stock amp/system with possible future upgrade to full C7 3 way component system. (Not sure what will fit?)
Remove convertible partition, and disconnect speakers directly behind the seat backs.
Dual 8" sub box in trunk with attached boxes for JL Audio C5 650-X co-axle speakers, all rear speakers speakers facing forward directly behind the folded down top, with dual Solo Baric L7 2 Ohm 8" subs ported @ 37Hz, fed by JL Amp powered mono at 2 Ohm.
Install sound deadening material in doors and rear, and build trim to cover exposed areas after convertible partition removal.
Was thinking about some backing cups/enclosures for the door woofers to prevent vibration and enhance performance if they fit.
Any insight, thoughts or suggestions?
Thanks!
I'm planning on using a pair of the Dynaudio MW182s for the door woofers and the Audiofrog GB25/GB10 for mid/tweets. M650 -> JBL MS-8 -> Biketronics BT4180 (2). Still waffling on a sub (Vettenuts w/JL 10W3V3) vs rears (Morel Tempo Ultra 502 Integra) or both.
Nav TV says the 650 can be setup anyway you need, using optical and analog flat stereo output at the same time and still retain the entire stock system if desired. The new JL amps are fully configurable from a phone app. Very cool stuff.
I looked at the Dynaudio and Audiofrog, very nice pieces. I think you should sub from the back though! The doors skins will pop off with 1000 watt subs hahaha.. No seriously.
If I had a coupe I would have one of those Stealth JL Sub boxes in a heartbeat!
