Targa weight
Old Jul 2, 2018 | 09:16 PM
Taevon lee's Avatar
Taevon lee
Default Targa weight
new stingray, thinking about removing the top for a little road trip tomorrow. Broke both shoulders years ago, racing. How much does it weigh, need to know if I can handle it alone. I am 6’2” not small, don’t want to drop it.
Old Jul 2, 2018 | 10:37 PM
Avanti's Avatar
Avanti
My salesperson at Kerbeck's told me 16 pounds.
Old Jul 3, 2018 | 08:04 AM
saleen556's Avatar
saleen556
As said about 16#. I take mine on and off all the time. It's extremely easy.
Old Jul 3, 2018 | 10:36 AM
RonC7's Avatar
RonC7
16# weight given above is for a carbon fiber panel. The transparent panel is 19#
Be very careful if it is windy - the roof is like a large kite!
Old Jul 3, 2018 | 12:29 PM
Maxpowers's Avatar
Maxpowers
With your shoulders, you might want to consider having someone help you the first time. Its not heavy but it can be a bit awkward.
Old Jul 3, 2018 | 01:28 PM
Jeff V.'s Avatar
Jeff V.
Good idea. Practice taking it off and putting it on a few times just in case. It can definitely be a little awkward.
Old Jul 3, 2018 | 02:31 PM
RonC7's Avatar
RonC7
TIP - double check weatherstrip is seated properly at the back edge of the roof above the windows before latching.
Old Jul 3, 2018 | 05:22 PM
saleen556's Avatar
saleen556
Agreed. I always pull the roof down into place and check before securing the levers. Haven't had an issue yet. Being tall definitely helps a bit. You'll be able to grab the middle of the roof making it not as awkward. Make sure trunk is open before pulling it off😄 Also make sure you know how it sits in the trunk before setting it in. I wasn't sure the first time making it harder than it had to be. Now takes less than 2 minutes being careful.
Old Jul 4, 2018 | 11:37 AM
Roadrogue's Avatar
Roadrogue
On advice here I bought one of those suction on handles for moving sheets of glass etc. Clamp it to middle of roof and it helps a lot. Don't have to reach as far which your shoulder might appreciate.
Old Jul 5, 2018 | 10:16 AM
hammong's Avatar
hammong
Awkward is the key word. Once you've done it a few times, it's easy - but lining up the pins and making sure you don't hit the painted surfaces with the panel is key. I usually prefer to have somebody sitting in the car that can make sure it doesn't "fall through" when setting it in place.
To Targa weight
