How-To: Remove/Replace Brake Fluid Reservoirs
1. Purchase x1 500mL bottle of brake fluid. The GM part number for the brake reservoir is 22968944 which is around $50. It includes everything you need (reservoir, x2 grommets, fluid level sensor and retention pin.
2. Unscrew the brake fluid reservoir cap. Use a turkey baster to remove as much of the brake fluid from the reservoir as possible. Only a small amount will be left in the reservoir afterwards, so spillage will be minimal when taking off the reservoir.
3. Unplug the fluid level sensor connector. Use a small screwdriver to release the tab.
4. Use a 5mm socket to remove the retention pin. You'll need a small 1/4" ratchet and 4-6" extension. Instead of being press fit in like most reservoirs it's actually threaded.
5. Carefully pull the reservoir out. It's only being held onto the master cylinder with two barbs with rubber grommets on them. If it doesn't pop right off, tilt it to one side and slowly shimmy it out.
6. This is what you will see now. DO NOT siphon out the brake fluid from the two openings, leave it alone. Be very careful not to spill it. Very carefully remove the x2 rubber grommets, a small pair of pliers works perfectly. Carefully inserts the x2 new rubber grommets.
7. Install the new reservoir. It requires a bit of muscle to push down.
8. Use the 5mm socket to install the new retention pin and plug in the sensor.
9. Pour in new brake fluid and fill it the MAX line. It'll be about 375mL or 80% of the bottle. Screw on the cap, pump the brakes and you're done!
Thanks for the detailed write up!
Yes, the C7 reservoir also uses a chambered design. You will not be able to siphon all the fluid out but the amount of fluid left in there really isn’t a lot. A towel wrapped around underneath the reservoir soaked up all the remaining fluid that came out..
