Aftermarket audio upgrade
Old Jul 28, 2018 | 11:09 PM
Jnemerow's Avatar
Jnemerow
Default Aftermarket audio upgrade
I want to upgrade my speakers and subs in my vette but want to keep factory head unit, have done a little research and wondering what setups others have done, I used to have Hertz high energy 3 way components in my last vehicle and loved them so am leaning to getting those and jl stealth box but am curious as to what other people have done, also not sure about what amp to go with and other things I need...
Old Jul 29, 2018 | 07:58 PM
DWillys's Avatar
DWillys
Kind of depends on what you're looking for, what you can DIY or what your installer is capable of, and what you're willing to spend.
Old Aug 1, 2018 | 10:54 AM
King_C7's Avatar
King_C7
In order to get the best sound possible while using your factory radio you will need to go with a DSP (Digital Sound Processor) The speaker outputs coming out of the factory Bose systems are time aligned, EQ'd and crossed over. A DSP will strip those settings into a clean flat signal and then you apply your own settings to the outputs to your new amplifiers. A 3-way component set and a centre channel with a sub would sound really good. As for amplifiers, it all comes down to how much power you want to make.
Old Aug 9, 2018 | 06:31 PM
JMII's Avatar
JMII
Based on my research and past experience with BOSE the statement above is accurate. You have to replace everything because its a system. So the radio stays (it must since it controls other vehicle features), then add a DSP for EQ (equalization) and TA (time alignment), from there add whatever amps you need to power the aftermarket speakers as needed. I would ditch the factory sub for sure. I had an Alpine DSP in my two other vehicles and it sounded amazing!
The real challenge is how to tap into the factory radio output, there seems to be two options but one is DOUBLE the cost:
https://navtv.com/products/NTV-KIT838/m650-gm.html ($850)
https://www.sonicelectronix.com/item...DSP-MOST1.html ($415)
Old Aug 10, 2018 | 12:06 AM
Ghostnotes's Avatar
Ghostnotes
It can be a lot of work to do it right.
I'm running an LC8i. I replaced all the speakers (doors included). In a nutshell I had to splice into the factory amplifier outputs and run those to the input side to my LC8i and re solder the wires. From there the LC8 converts and sums the signal for all channels and sends the converted low voltage signal via (RCA) to the input side of my amps. The output then goes back to where i made my initial splice and it reconnects to the out going speaker wires.
There is no comparison in sound.
Also a problem you might run into depending on the level of work done is interference from the mic that picks up signal for sound cancellation. You have to disable it..
Old Aug 10, 2018 | 01:21 PM
JMII's Avatar
JMII
For sure. Based on my experience that AudioPilot feature is pretty much worthless once you go aftermarket since its compensation is based on the factory speaker frequency response. Glad to know the LC8i works, that make things pretty straight forward. However if you using the BOSE amp signal then you've still got all the factory EQ / DSP stuff applied messing up the signal. Instead I would go with a JL Audio Fix: http://www.jlaudio.com/fix-82-car-au...egration-98100
Old Aug 10, 2018 | 01:35 PM
DWillys's Avatar
DWillys
The Bose equalization/signal manipulation is volume dependent. Any DSP or devices like the Fix82 are at set up/tuned one volume making what they do a compromise. The only way to fully get rid of the Bose stuff is to get the NAVTV M650-GM, Axxess AX-DSP-MOST1, or PAC ap4-gm61. The AX-DSP-MOST1 has a built in DSP which can be a plus (DSP included) or a negative (cannot totally defeated to use your preferred DSP). The PAC AP4-GM61 is new to the market and hasn't been proved yet. The M650-GM and reportedly the AP4-GM61 are the only devices currently available that will produce a pure unadulterated output from the OEM sound system.
That's not to say you cannot get a better than stock results without the M650-GM/AP4-GM61/AX-DSP-MOST1. However to take it to the top level of sound you will need one of them.
Old Aug 10, 2018 | 04:53 PM
King_C7's Avatar
King_C7
I tried the LC8i first but it just didn't sound right to me. I tried everything but the bass just sounded muddy and uncontrolled on low volume. I went the Audison Bit One route and it made a huge difference in sound. Very clean and nice tight bass. The JL Audio Fix will work as well.
Old Aug 11, 2018 | 05:17 PM
JMII's Avatar
JMII
Great info! The PAC unit is the cheapest solution, plus has outputs at 5V with a subwoofer level control. Sounds like a winner but time will tell since it just launched. I'd keep an eye on this thread: https://www.diymobileaudio.com/forum...-ap4-gm61.html I want a flat signal to feed into a Rockford Fosgate DSR1 so I can play with the EQ using my iPad. Currently the RF unit seems to have the best UI for doing this, most other DSP require a laptop hardwired over USB to adjust them.
Old Aug 12, 2018 | 08:23 PM
Kevz14's Avatar
Kevz14
8th Gear
Default Aftermart audio upgrade
Hello all,
This is my first time posting and I’d like to share what I’ve done audio wise in my C7. First off I’ll run down a list of my equiptment.
JL Audio HD 900/5
JL Audio TWK-88
JL Audio Fix-86
2 Sets of JL Audio C5 Components
JL Audio 8W7ae
Old Aug 12, 2018 | 09:16 PM
jonparks's Avatar
jonparks
Old Aug 12, 2018 | 09:30 PM
jonparks's Avatar
jonparks
This works pretty well. Not overly loud but with a 10 in sub and Focal setup it sounds clean and tight.
Old Aug 12, 2018 | 10:34 PM
Citation's Avatar
Citation
Do a full insulation kit (not just the carpet mat) in your car and you'll be happy with the Bose audio system. Makes a huge difference. It will take a full day to take everything apart including removing the seats but still way cheaper than any of the options above.
Old Aug 13, 2018 | 10:15 AM
JMII's Avatar
JMII
Where did you put the 10"? Looks like its hiding out in the small cubby in the very back.
Not me. Even if the car was perfectly silent the Bose system would still be sub par compared to what I can get out of a small aftermarket upgrade.
Old Aug 16, 2018 | 05:25 PM
Kevz14's Avatar
Kevz14
8th Gear
Default Finished and sounds great!
Originally Posted by Kevz14
Hello all,
JL Audio HD 900/5
JL Audio TWK-88
JL Audio Fix-86
JL Audio 8W7ae
Old Aug 17, 2018 | 04:32 PM
JMII's Avatar
JMII
Beautiful work... and great color choice with the green. My heart was set on the blue but when I saw the green I almost changed my mind... notice I said almost
Old Aug 20, 2018 | 02:19 AM
Kevz14's Avatar
Kevz14
8th Gear
Thank you!
To Aftermarket audio upgrade
Old Aug 20, 2018 | 03:39 PM
Tin-can's Avatar
Tin-can
Can you provide additional info on "full insulation kit" for an '18 GS? This sounds more attractive than re-doing the sound system. It seems like a good idea to reduce ambient noise before doing anything to the sound system.
Old Nov 8, 2018 | 01:29 PM
427C62013A's Avatar
427C62013A
I've done this on two other Vettes with good results. I have started on the third... Vettenuts.net or Crazy Cowboy are sources for insulation kits that are pre-cut for the car. Not an easy task. The removal of the interior is required but the results are worth the effort.
Old Jan 16, 2020 | 04:41 PM
Flash_Gordon's Avatar
Flash_Gordon
St. Jude Donor '17
Just wanted to point out that the 650-gm is now only $499.
I'm shopping for C7's, while simultaneously searching for ways to upgrade the sound system once I have it and came across this thread. This has been a big help. Seemed easier in the C6, but then again, the head unit was easily replaced.
